Dell Vostro 5402 P130G002 MKB-V TGL 8L MB 19862-1 WTXV4$JA clean me
  • hoaca388
    Badcaps
    • Jan 2022
    • 12423
    Originally posted by Bios White
    Service Tag ok, choose Model ok BUT not install SSD , please build BIOS qayyum786, minhdigital hoaca388
    Find hardware problem
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      Try last one
      • Bios White
        Learn
        • Dec 2024
        • 88
        • East Laos
        Old bios SSD ok, No change sericetag ,
        • hoaca388
          Badcaps
          • Jan 2022
          • 12423
          Which bios is ok with you ?
          • Bios White
            Learn
            • Dec 2024
            • 88
            • East Laos
            Originally posted by qayyum786
            Try last one
            qayyum786 Ver 1.24 , SSD ok, no change servicetag .....
            hoaca388 Bios ok tag ok, ssd ok ,
            • hoaca388
              Badcaps
              • Jan 2022
              • 12423
              #26
              • Bios White
                Learn
                • Dec 2024
                • 88
                • East Laos
                #27
                no power , thank
                • qayyum786
                  • Aug 2018
                  • 1959
                  • INDIA
                  #28
                  Try
                  At first boot save service tag manually from bios setup
                  2nd boot press Alt+F to exit manufacturing mode
                  • Bios White
                    Learn
                    • Dec 2024
                    • 88
                    • East Laos
                    #29
                    Try
                    Done 100%, thank you for hoaca388 and qayyum786 help me
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #30
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        #31
                        • eudula
                          • Oct 2019
                          • Brasil
                          #32
                          Hello!
                          I have a DELL Vostro 5402, with a password.
                          I downloaded another BIOS, but I can't save the ST and I can't exit manufacturing mode
                          Dell Vostro 5402
                          ST: BNW48K3
                          MOTHERBOARD: 19862-1
                          Can you help me?
                          backups of the original BIOS.Thank you.​
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12423
                            #33
                            Originally posted by eudula
                            Hello!
                            Dell Vostro 5402
                            ST: BNW48K3
                            Can you help me?
                            3.4. Dell
                            Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                            See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                            Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                            Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                            Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                            Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                            Note: There is no publicly available 8FC8 generator available at the moment.
                            The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                            8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                            • eudula
                              • Oct 2019
                              • Brasil
                              #34
                              Thank you very much hoaca388 ca388, the 8FC8 Patcher Software worked perfectly.​
                              • Satus
                                • May 2016
                                • 20
                                • South Africa
                                #35
                                Good day all
                                Please can someone help me repair this bios file, i have try all the bios bin on this tread but I'm unable to save the Service Tag Number
                                the original bin file no display
                                Dell Vostro 5402
                                Service tag: 35krw93
                                • ridouane
                                  • Mar 2019
                                  • 37
                                  • casablanca
                                  #36
                                  Hi!
                                  My devices is Vostro 5402, someone put password on it
                                  Dell Vostro 5402
                                  ServiceTag: 2QC3Q93
                                  MAINBOARD code: MKB-V TGL 8L MB 19862-1
                                  Can someone help please?
                                  This is my bios original backups
                                    • 22182
                                    Originally posted by ridouane
                                    Hi!
                                    Dell Vostro 5402
                                    ServiceTag: 2QC3Q93
                                    Read that post, try the patcher https://www.badcaps.net/forum/troubl...77#post3658177
                                    • ridouane
                                      • Mar 2019
                                      • 37
                                      • casablanca
                                      #38
                                      THANK YOU SMDFlea.
                                        DELL Vostro 5402 Notebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Vostro 5402 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5402 boardview and 5402 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 5402 Notebook...
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 11:20 PM
