Unlock SVP Lenovo Thinkpad T14 Gen2
I’ll wait to see what happens next; we also don’t know if Santoslao will put the original back in to see if the error disappears.
In any case, if error 0177 is present, it means something has been changed somewhere.
Especially since he seems to be talking about the loss of serial numbers, etc.
As can be seen in the LBE images, some fields remain invalid after unlocking.
I have unlocked over 100 units across the entire Mec17xx series. While some devices encountered issues during the initial stage—specifically when applying patches during the boot process—I have successfully resolved all of those errors.
I am still here to support you, but I cannot share this unlocking solution. I hope you understand.Comment
I know where the 0177 error is coming from, but I don’t have access to a computer right now. As a result, I won’t be able to resolve this for another two days. If you’re willing to wait, I can help you fix the 0177 error in about two days—it’s actually quite simple.Comment
dude, many thanks so far! great.Comment
when I return the original file of the machine, it turns on normally, there are no changes, but it still has the password in the bios. Error 0177 only appears when installing this modified file from the post. #414 The machine shuts down immediately following error 0177, leaving no opportunity to boot from a flash drive via U1 or any other system.
Maxpower3
24HLAPTOPComment
I installed this file again without the SVP correction and the machine turned on, gave error 0177, I turned it on again with the U1 and it came to the QRcode screen, I chose the option without QRcode!
Every time I restart it generates new codes, what's the next step, it's off now!Comment
santoslao Once you have accessed the QR interface, we will have sufficient data to unlock the device. Simply plug in a USB drive to extract the text-based data and send the resulting text file to me—or, alternatively, provide a clear photo of the QR code—and I will be able to unlock it for you. Please note that the QR code is valid for only two hours; therefore, please message me only when you are online so that I can decode it for you.Comment
see..santoslao Once you have accessed the QR interface, we will have sufficient data to unlock the device. Simply plug in a USB drive to extract the text-based data and send the resulting text file to me—or, alternatively, provide a clear photo of the QR code—and I will be able to unlock it for you. Please note that the QR code is valid for only two hours; therefore, please message me only when you are online so that I can decode it for you.Attached FilesPremium supporters get full download access and other benefits.
I can only guide you through the initial steps regarding the QR code for now. Let’s reconnect in two days; I will then provide you with the QR code. I’m currently away on a business trip abroad and didn’t bring my computer with me—the unlocking software I use is back home. You are following my instructions correctly. If you re-flash the original BIOS file I sent you—the one from our first exchange—and are able to boot into the BIOS (where a QR code appears) without encountering the 0177 error, then the root cause was indeed what you mentioned: you had mistakenly flashed a BIOS file from a different machine, which triggered that error. santoslaoComment
With the machine's original file, it normally connects without errors, but with a password. The SVP error appears with the password you gave me. In any case, I already have the machine's data saved to add them back using U1 if necessary. The SVP error only appears after installing the file from post # 414 above. Disregard the first file I sent, it was not from the machine.
so I will have to wait for two days when you come back, I will turn off the machine, as I thought it would be for now, anyway, thank you for your attention and for giving your time to the case.Last edited by santoslao; 10-29-2026, 09:23 AM.
Thank you very much, my friend—it worked perfectly! Well done!I can only guide you through the initial steps regarding the QR code for now. Let’s reconnect in two days; I will then provide you with the QR code. I’m currently away on a business trip abroad and didn’t bring my computer with me—the unlocking software I use is back home. You are following my instructions correctly. If you re-flash the original BIOS file I sent you—the one from our first exchange—and are able to boot into the BIOS (where a QR code appears) without encountering the 0177 error, then the root cause was indeed what you mentioned: you had mistakenly flashed a BIOS file from a different machine, which triggered that error. santoslao
Thinkpad T16 Gen2 MEC1723 (unlocked)
NM-E972Comment
I occasionally get few of the locked MEC1723 lenovos, would be really good if there was a solution to unlock floating around someday ...Comment
Could someone help remove the BIOS password! I thank you in advance!
T14 Gen 4 MEC1723
NM-E972
PE0DY8QM
HI USB BOOT U1KY THEN FLASH BIOS THEN SEND CODE
I WILL WRITE IT LIKE THAT IN OUR PROGRAM IN HELP TAB
PART 1 - Patch the BIOS
1. Read the laptop BIOS chip (CH341A programmer) to get a dump.
2. Patcher tab -> Browse -> pick the BIOS file -> Patch File.
3. The patched file is saved in a folder named <name>_v11.
4. Flash the patched file back to the chip.
OR: Create Boot USB -> set Secure Boot OFF -> boot the USB
(it injects the certificate for you).
PART 2 - Get the unlock code
5. Power on the laptop. The "Certificate-based Authentication" QR
screen appears.
6. Take a clear photo of the QR code.
7. Decoder tab -> Load Image -> pick the photo -> Decode.
8. A 16-digit code appears (auto-copied).
9. Type the code in the laptop "unlock code" box -> OK.
The BIOS opens.
PART 3 - Remove the password
10. Enter BIOS Setup (F1) -> Security.
11. If asked: enable Secure Boot, then disable it.
12. Open "Reset / Clear Supervisor Certificate" -> a new QR appears.
13. Photo -> Decoder -> Decode -> new code -> enter it.
14. Set your own new supervisor password -> Save -> restart.
15. Enter your new password, go to Security, and remove it.
16. Done - the laptop now has no password.Attached FilesPremium supporters get full download access and other benefits.
Thinkpad T14 Gen 4 MEC1723 (unlocked)
NM-E972
This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 09:45 AM
This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 09:40 AM
by GrafnusHey there,
first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
Specs:- Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
- CPU, GPU, RAM work fine (not involved in the Problem)
So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
Now I noticed... - Loading...
