Unlock SVP Lenovo Thinkpad T14 Gen2
...like in your second MEC1503 video on YouTube, right ? 😉
Maxpower3 commented
Today, 06:07 PM
You think LBE uses a modified LPC method ?
But some people have tried it, and it freezes.
They're pros; it must be something else—maybe via USB.
From what i understand ( i can be wrong)
we are still dealing with the lpc hack.
but the espi bus is much faster so it can not be done manually
now if you goto hi hi posts he gives a type of tool that can be used.
and he also gives an idea of the attack window.
I see that we are currently on the torture state, occurs very often right before the release of a hack like "well... we have it but we not releasing...., perhaps it this or perhaps is the other way"
Eventually someone will reveal it.Comment
Not a problem at all. Personally, I don't have much respect for those who benefit from the Forum but refuse to share solutions that were clearly inspired by information already available in its threads. I don't want "their" help. The same goes for those selling 8FC8 passwords here (they may think I don't know, but I do)
After all, what do you get when you pile trash on top of trash? A bigger pile of trash.Comment
<3
disturbing the mec1503 internal regulator by replacing VR_CAP with 5k up to 50k resistor mine 20k is working. ESPI_IO0 ground it before entering bios menu or use tact switch 1 second or less make sure to close the TAMPER_SW. done 4 t14 gen 2 and 1 yoga gen 6.
this work only for MEC1503Comment
Thank you, valtic , for all the detailed and clear instructions. That's the spirit of a community! 👏disturbing the mec1503 internal regulator by replacing VR_CAP with 5k up to 50k resistor mine 20k is working. ESPI_IO0 ground it before entering bios menu or use tact switch 1 second or less make sure to close the TAMPER_SW. done 4 t14 gen 2 and 1 yoga gen 6.
Thanks for sharing!disturbing the mec1503 internal regulator by replacing VR_CAP with 5k up to 50k resistor mine 20k is working. ESPI_IO0 ground it before entering bios menu or use tact switch 1 second or less make sure to close the TAMPER_SW. done 4 t14 gen 2 and 1 yoga gen 6.
So Maxpower3 this is the way to go or there is a simplest solution?Comment
It's an interesting solution, perhaps a bit complicated for some people.So Maxpower3 this is the way to go or there is a simplest solution?
Does the solution work every time?
Do any freezes occur?
We're lacking some information.
I'm waiting to see the feedback.
But I don't need to do all that, and neither does LBE.
i played a bit yesterday. it didn't work, but i tested only a few times (with different setups - lower and higher ohm resistors, use a tactile switch! you should use the lenovo usb stick, too for a faster boot process)... i can't confirm this is working right now, the system is much more tolerant against glitching, but the time the svp quey should be skipped, the system will eventually freeze. but there are different ways, this one is interesting...Comment
ThinkPad gen 2 svp bypass no resistor modification only 2 attempts ESPI_IO0 to GND
https://youtube.com/shorts/nmUkQMoIn...IeNILs1G1Uk3hcComment
I don't get it.ThinkPad gen 2 svp bypass no resistor modification only 2 attempts ESPI_IO0 to GND
Why everyone else who tried it get the laptop frozen?Comment
This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 09:45 AM
This specification for the Lenovo ThinkPad X1 Yoga + USB-C Dock Gen2 (40AS0090AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + USB-C Dock Gen2 (40AS0090AU) boardview and X1 Yoga + USB-C Dock Gen2 (40AS0090AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 09:40 AM
by GrafnusHey there,
first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
Specs:- Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
- CPU, GPU, RAM work fine (not involved in the Problem)
So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
Now I noticed... - Loading...
