HP Elite x360 830 G9 2-in-1 bios unlock
I first tried with a CH341B programmer I have modified it to ensure 3.3v on the data pins) and sop8 clip adapter with the plastic tips of the clip ground down. No use.
Then soldered short wires to the chip. I didnt disconnect the battery so could have shorted two pins?
Then removed the chip with a heat gun and soldered it to a sop8 adapter with the solder pad underneath the chip insulated with tape to avoid shorting the pins. Asprogrammer says no chip detected. I've bought 2 new W25q256jven chips which detect and read fine soldered the same way to the same adapter. I'll try the original again tonight.
Can firmware from another laptop not be used?
Thanks.Comment
I have laptop with bios issue hp elitebook 830 g9 board #6050a3316601 my laptop is not x360 plz send me the forum link without x360 laptopComment
Ok, try again tonight. We need to see which version your board uses (U70/U71/U76) before we can give you the correct BIOS files. If it still won't read, post the EC instead.
Thanks.Comment
Yeah pretty sure the SPI chip is brown bread 💀
Please see uploaded EC Chip. (Although I managed to Donald Duck a few caps and resistors 😪 Hopefully I can Feng Shui them back into place
Details again:
HP Elitebook 830 G9
Product ID: 4B5S1AV
Serial: 5CG30912RW
Build ID:22WWWPAT602#SABU#DABU
Feature Byte:
476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdpdqfPgSguhKjhk8mEn7nVngpDpFpVpqqjqz.F4 (Please note I think Feature Byte was 1 character incorrect in my previous post)Attached FilesPremium supporters get full download access and other benefits.
There was no need to desolder the chip, but I hope you solder everything back correctly in place... Good Luck!
HP EliteBook 830 13.3 inch G9 Notebook PC
BIOS and System Firmware (U70) Version: 01.17.00 Rev.AAttached FilesPremium supporters get full download access and other benefits.
Successfully wiped new W25Q256JVEN chip, flashed and verified new bios file. Thanks very much Sparo.
I haven't soldered chips back yet as I'm playing Solder Curling with these little resistors and caps I nudged. I made the mistake of trying to grip one of the little resistors with needle nose tweezers and slipped firing it into another dimension.
Can anyone find out what resistance this one is?
10 or 33 ohm , measure the one next to it, should be the same
I get 5ohm on the 2 below it and 6ish on the 3rd one down.
The closest I could find on scrap boards is 3ohm.
Surprisingly it won't boot. Just gives white/slight orange led by the USB-C charging port. Tried unplugging and holding power button for 15+ seconds.
Think I've frazzled it or just wrong resistor?
Edit: Couple of caps have undone themselves when putting the EC chip on. Fingers crossed.....Comment
hello, need help
HP Elitebook 830 G9
SN:5CG3231VG9
MB:6050A3316601-MB-A01
NO DISPLAYAttached FilesPremium supporters get full download access and other benefits.
hello, need help with bios unlocking
mb:6050A3469701
SN :5CG31237Y9
MODELO:HP Elite x360 830 G9 2-in-1
EC_BAK :
SPI_BAK :Attached FilesPremium supporters get full download access and other benefits.
post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
read the forum rules..
Hello, gentlemen.
I need some help, need to remove a BIOS password.
Serial - 5CG2421724
Product ID - 5P791EA#ABH
Build ID - 22WWWPAT602#SABH#DABH
Feature Byte - 476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAdpdqfAfPfXguhKhkjhk8mEmGmwn7nVngpTpWpppqqjqz.q5Attached FilesPremium supporters get full download access and other benefits.
Can someone plese help to unlock bios password for this laptop?
SN@ 5cg24219wr
tried all methods i found online, none worksAttached FilesPremium supporters get full download access and other benefits.
Hi, write both U70 files from here > https://www.badcaps.net/forum/troubl...90#post3672790Hello, gentlemen.
Serial - 5CG2421724
And then fill in these DMI information using BCU
Serial Number: 5CG2421724
Product #/SKU: 5P791EA#ABH
CT Number: PMYEE00WBH50BQ
Description: HP Elite x360 830 13 inch G9 2-in-1 Notebook PC
BuildID: 22WWWPAT602#SABH#DABH
Feature Byte: 476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAdpdqfAfPfXguhKhkjhk8mEmGmwn7nVngpTpWpppqqjqz.q5
MAC Address: 38:CA:84:56:AC:CD
Cirrus Discrete Amp Calibration Data: 3000000002000000196513015DD40A00003240F803E9D80100016F25196813015DD40A00E0ADB3FB03E9D8010001CC25
Universally Unique Identifier (UUID): 8AEBE2A479D3174796F5F9B9C0D9D62F
UUID (standard format): A4E2EB8A-D379-4717-96F5-F9B9C0D9D62F
MS Digital Marker: 010000000000000001000000000000001D000000344639474B2D564E5137372D464633344B2D57324A42332D56584D3647Comment
by ArzigolHello everyone!
I am looking for experienced BIOS modders who can help analyze or unlock the BIOS of my Acer Nitro Lite 16 NL16-71G.
Please note that this post was written with the help of ChatGPT because my English is limited. My native language is Russian. If anything is unclear, please let me know and I will do my best to explain.
Laptop Information
Model:
Motherboard:
CTE_NB_NL160P1G_RTH (NB6807C)
CPU:
Intel...-
Channel: BIOS Requests ONLY!
by cqdlyHello Need bios unlock for hp Elite x360 830 G10 2-in-1 SN:5CG33350LJ thank's in advanced...
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
by whelanm87Hi everyone,
I’m working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. I’ll be posting my own backups for reference and comparison.
🔍 System Details- Model: HP Envy x360 15-fe0053dx
- Product Number: 7HVO3UA#ABA
- Build ID: 23WW2GQZ6D
- Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
- Motherboard SPS: N30979-ABA
- LCD SPS: N49271-601
- Date Code: 172380
- Keyboard Type: 0
- Feature Byte:
3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
hZnp.praepq0Md4qkdf
🔧 Chip Info- Main BIOS chip: Winbond W25Q128JVSQ
- Loading...
