Lenovo W541 Whitelist removal
  • Bill_Carson
    • Mar 2021
    • 8
    Hi All,
    I wonder if anyone can help me please.
    I would like to see if someone can remove the hardware whitelist that is applied to the BIOS of my Lenovo W541 laptop? it prevents you from adding a newer Wi-Fi 6 card such as the AX200 / AX210.
    Kindest regards,
    Bill
  • techcraze
    Lenovo 15ARH05 LCD whitelist removal request (Yes. display whitelists....)
    by techcraze
    Long story short. i am building a fully custom car radio. and want to use a extremely bright LCD.
    sadly the DGPU seems to be nonfunctional after i fixed the bios (fried voltage controller). so the Original HDMI port does not work.
    you can use a EDP TO HDMI adapter to add a HDMI port as replacement to the onboard EDP LCD connector,
    HOWEVER it turns out. lenovo enforces a LCD whitelist.
    this means you cannot upgrade the LCD despite matching EDP specs and voltages.
    If i connect a new screen directly to the system. only static shows....
    05-08-2025, 07:50 PM
  • danro
    wifi whitelist Lenovo M920x
    by danro
    Please remove wifi whitelist from this Lenovo bios.
    If try to use another wifi card, unit no boot
    Original card: Intel8265NGV
    ThinkCentre M920x
    Model: 10S0S0GX00
    SN: PC12PQSF
    Here is the original dumps
    Thanks....
    07-17-2025, 03:48 PM
  • xsd611
    Lenovo X270 Bios - remove Whitelist
    by xsd611
    ​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
    07-13-2025, 09:13 PM
  • memoslar
    Password removal Lenovo ThinkCentre M70q
    by memoslar
    Hi, i want password removal of Lenovo Thinkcentre M70q please.
    The board is iq6x0il2.
    I attach the bios bin.
    Should i upload the second bios code? (ec)...
    11-20-2024, 02:16 AM
    Lenovo ThinkPad W541 W540 Wistron LKM-1 WS 12291-2 12291-1 Schematic & Board View
    Lenovo ThinkPad W541 W540 Wistron LKM-1 WS 12291-2 Schematic & Boardview...
    10-02-2024, 01:41 PM
