Need dump for Asus Zenbook 14 UX5401ZA
  • hipernk
    • Oct 2016
    • 5
    • Venezuela
    Hello, I received an Asus Zenbook 14, model UX5401ZA at the workshop, the customer tried to update the bios of the machine and canceled the process before finishing, now it does not show an image, it turns on but does not boot, the charging LED flashes twice and then pauses.
    I have downloaded the bios directly from the Asus website but it is in .308 format, I have also made a backup of the bios that it currently has and the difference is 4MB between the two.
    I attach both bios, I need help to get the bios in format to be able to program with the EZP2019+
  • SHONE984
    • Mar 2022
    • 36
    • stockholm
    hello. i need help whit uefi bios pass . asus zenbook 14 ux5401z any help
    • peste
      • Dec 2016
      • 13625
      • ROMANIA
      post S/N, full name and model, motherboard model,etc.
      • SHONE984
        • Mar 2022
        • 36
        • stockholm
        ASUS UX5401Z NoteBook PC sn 12M N5N0CV00V74418E Motherbord ux5401za r2.2
        • peste
          • Dec 2016
          • 13625
          • ROMANIA
          try..
          • SHONE984
            • Mar 2022
            • 36
            • stockholm
            I screwed up. I put the chip on the wrong side, and now the laptop won't turn on. I tried with the original bin but the same thing happens.
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
