Need dump for Asus Zenbook 14 UX5401ZA
  • hipernk
    • Oct 2016
    • 5
    • Venezuela
    Hello, I received an Asus Zenbook 14, model UX5401ZA at the workshop, the customer tried to update the bios of the machine and canceled the process before finishing, now it does not show an image, it turns on but does not boot, the charging LED flashes twice and then pauses.
    I have downloaded the bios directly from the Asus website but it is in .308 format, I have also made a backup of the bios that it currently has and the difference is 4MB between the two.
    I attach both bios, I need help to get the bios in format to be able to program with the EZP2019+
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • DynaxSC
    by DynaxSC
    06-14-2024, 03:49 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • harshadcpalace
    ASUS Zenbook 14 UM425IA BIOS dump
    by harshadcpalace
    Hii Brother
    anyone have EC firmware for this laptop
    ASUS Zenbook 14 UM425UA
    post moved..
    01-19-2025, 12:38 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
