Lenovo Thinkpad T14 Gen3 Bios Password
  • charli
    • Jul 2016
    • 29
    • Serbia
    #41
    I have a Lenovo ThinkPad T14 Gen 3, motherboard nm-d882, serial: pf4gpbeq, then have admin password
    Please unlock?
    Thank you
    • elbas
      • Mar 2026
      • Bosnia & Herzegovina
      #42
      I need help with my Lenovo ThinkPad T14 Gen3 AMD laptop. Board is NM-E441 rev.1.
      Machine Type: 21CG-S32FV00
      Serial number: PF-4E1M7Z
      Board: NM-E441 rev.1 (JT4C1/JT6C1/JP6C1)
      BIOS chip: 25R256JWEQ (32MB) EC chip: 25LB128ESIG (16MB)
      Original problem: Fan spinning on startup, black screen, laptop turning on by itself without pressing power button. I suspect EC firmware corruption.
      I have read both chips with CH341A programmer using NeoProgrammer software:
      • 25LB128ESIG (EC chip) - 16MB dump - read from already corrupted board
      • 25R256JWEQ (BIOS chip) - read from corrupted board
      I need clean dumps for both chips from a working NM-E441 rev.1 board:
      • Clean BIOS dump for 25R256JWEQ chip
      • Clean EC firmware dump for 25LB128ESIG chip
      Both of my corrupted dumps are attached to this post.
      Thank you in advance!
      โ€‹
      • peste
        peste commented
        Editing a comment
        post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
    • Sparo
      • Jan 2022
      • 1196
      • MA
      • Anime, Edge Computing, Football, Snooker
      #43
      Hi leave your 16MB chip as it is and flash this 32MB BIOS file only it should work for you I think
      It's the same BIOS Version as yours Ver 1.35 (R23ET65W) and I aso matched your EC Version 1.25 (R23HT59W)
      I've already injected your Windows key as well. Good luck!
      T14 Gen 3 (Type 21CF, 21CG) Laptop (ThinkPad) - Type 21CG
      Machine Type Model 21CGS2FV00
      WinKey/1180000-118FFFF
      Enjoying our forum? Help keep it running and unlock extra perks!
      >> Upgrade here <<
      ๐Ÿš€๐Ÿ’ฌ๐Ÿš€
      • elbas
        elbas commented
        Editing a comment
        Thank you very much for your help and the BIOS file! Verify passed successfully and file is correctly written.
        Unfortunately the problem remains the same โ€” black screen, no display output on internal or external monitor (HDMI).
        This narrows it down to either EC firmware corruption or physical board damage.
        Since my EC dump was read from an already corrupted board, would you be able to provide a clean EC dump for 25LB128ESIG chip as well?
      • Sparo
        Sparo commented
        Editing a comment
        Okay Try flashing files from Post #'2 by Maxpower3 and see
        > https://www.badcaps.net/forum/troubl...12#post3155512
      • elbas
        elbas commented
        Editing a comment
        I have tried this dump as well but the behavior is the same.
        I have ordered new EPROM chips (25256 and 25LB128ESIG), when they arrive I will flash your files on fresh chips to eliminate the possibility of damaged EPROMs.
        Will keep you updated!
    • selek3
      • Jul 2021
      Hello, is there still no way to remove the SVP on a T14 Gen 3 with Intel? Svod4, bypass, or any other methods?
      • conectasat
        Lenovo Thinkpad E16 Gen3 BIOS password
        by conectasat
        I have this unit with an administrator password set in the BIOS. Would it be possible to unlock it to remove the password and restore full functionality to the device?
        SN: PF-5M9ESH
        Type Number: 21SR-000QSP
        Compilance ID: TP00166A
        NM-G691 R 1.0
        โ€‹โ€‹โ€‹โ€‹โ€‹
        โ€‹โ€‹โ€‹ Thanks everyone!...
        03-06-2026, 04:06 PM
      • RMDUiFT
        Should I buy a Lenovo Thinkpad E495 with bios password?
        by RMDUiFT
        Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
        I have a few questions:
        • If I would buy this laptop and have
        08-25-2024, 09:00 AM
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Dudebroman
        Lenovo Ideapad Slim 3 Bios Password Ghost
        by Dudebroman
        Hello Hello,
        I have been browsing the site and gotten so much useful info from here, including extremely helpful boardviews and several other very useful types of information. I am very grateful to this community, as I have actually eeked out a living from buying salvage PC's & Macbooks and repairing them. So, thank you all in advance!
        I have searched and found some useful information regarding my issue, but my case is a bit different than the info I'm finding. But if anyone here can give me any useful advice, it would be highly appreciated.
        12-18-2025, 12:22 PM
