need bios HP 245 G8 bios
  • dqtech
    Badcaps
    • Jul 2018
    • 630
    • N/A
    laptop no display issue....customer sent this laptop the other shop and i figure out they try to flash bios without remove bios ic from motherboard...
    board number :-
    6050A3213801-MB-A01
    • 21145
    Re: need bios HP 245 G8 (6050A3213801-MB-A01)
    board number :-
    6050A3213801-MB-A01
    The laptop serial number is 5CG1470YLG .Go to HP support,download and extract the bios update
    [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/showthread.php?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
    Your BID number is BID08908
    Copy the DMI from the backup to the new bios with a hex editor, using these offsets
    414000 - 41503F and 436000 - 43603F
    • ROONEY50
      • Aug 2024
      • 3
      • United Kingdom
      I need a clean bios for my HP 245 G8.
      serial number 5cg11645s9
      I'm trying to upload the old dump but there is no option to upload it 😑
      • Darren Hibbert
        Darren Hibbert commented
        Editing a comment
        As promised Rooney, here is your old bios that i have uploaded using my profile.
      • ROONEY50
        ROONEY50 commented
        Editing a comment
        Arrrhhh many thanks. Don't know why I cant upload the file myself but I am a new user.
        Hopefully someone can fix my bios for me.
      • 21145
      Thread merged.
        • 21145
        HP 245 G8 Notebook PC (34Q11ES)
        There are 2 different bios updates at HP support, the first one is not yours as that is SSID 8908 ,and your bid is BID085B1. The second bios update "HP Notebook System BIOS Update (AMD Processors)" has your bios inside it.
        Click image for larger version  Name:	Two different bios versions.jpg Views:	0 Size:	24.7 KB ID:	3335349
        The bios can be extracted using the guides at post 2 ,run the exe first and if it gives you the option to save to a location do that, otherwise it will need extracting using AMIUCP. There are 3 different bios updates in the exe , @R00 ,@R01 and @R02 .Its @R02 that is BID085B1
        Your DMI. Copy it using a hex editor from your old bios to the new one
        DMI 283000 - 283FFF
        KEY 2A5000 - 2A503F
        • ROONEY50
          • Aug 2024
          • 3
          • United Kingdom
          Sorry but I dont really know what im doing.
          Can someone upload the new bios file so I can program it to my BIOS chip like they do in the other posts? My old bios is attached above.
            • 21145
            Ok
            • Darren Hibbert
              • 114
              Many thanks for that.
              Much appreciated πŸ‘ πŸ‘ πŸ‘
              • M4n0l0307
                • Nov 2020
                • 167
                • Colombia
                Thanks friend !
                • abhorsen
                  Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                  by abhorsen
                  Hey guys,
                  Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                  Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                  Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                  07-06-2023, 10:22 AM
                • mrrubik
                  Dell Optiplex 7010 micro bad BIOS flash?
                  by mrrubik
                  Hi folks,
                  I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                  After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                  Steps I took:
                  1. Read BIOS with CH341a, verified hash twice
                  2. Patched
                  12-23-2024, 04:11 PM
                • James Jackson
                  Panasonic CF-20G0247VM BIOS Bad Flash Help
                  by James Jackson
                  I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                  Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                  05-01-2025, 11:28 AM
                • spmetroil
                  Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                  by spmetroil
                  I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                  The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                  I have a CH341A programmer and I already attempted the following steps:
                  1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                  2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: β€œChip with the contents are in disagreement.”
                  3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                  08-19-2025, 09:23 AM
                • what_1282105
                  Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                  by what_1282105
                  Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                  02-14-2025, 07:27 PM
