Recovered 850 G1 Bios now the warning machine not in committed state
  • Ginjaninja
    • Aug 2021
    • 13
    • United Kingdom
    Hi all just wondering if anyone can help?
    i have just recovered my bios after i screwed it up after trying to take a dump of my bios with a clip and a programmer to get around the bios password on one of my old work laptops (HP Elitebook 850 G1).
    since the recovery i have been left with the PC now booting up but now i get the warning the machine is not in a commited state and the laptop swithes itself of after about 30 minutes, which i believe is to do with a missing intel management engine.
    if anyone can shed any light on wither of these problems, which i am guessing they are both related to a possible bad BIOS.
    TIA
    The NiNja
  • hardware1
    • Sep 2021
    • 2943
    • N/A
    Re: Recovered Bios now the warning machine not in committed state
    TIA
    The NiNja
    Read this to learn how to clean ME Region.
    https://www.badcaps.net/forum/showthread.php?t=88533
    all donations are welcome,
    • Ginjaninja
      • Aug 2021
      • 13
      • United Kingdom
      thanks very much for the reply i'll have a read
      Thanks the NiNja
      • Ginjaninja
        • Aug 2021
        • 13
        • United Kingdom
        just one other question do i need to use my bios clip and prorammer to use the Intel FIT
        TIA
        The NiNja
        • hardware1
          • Sep 2021
          • 2943
          • N/A
          TIA
          The NiNja
          I don't prefer to use clip unless you don't have proper tools (soldering iron/hot air) or your soldering skills isn't good.
          If you are not sure that you can clean the ME Region by yourself, upload the file here and someone will try to help you.
          • Ginjaninja
            • Aug 2021
            • 13
            • United Kingdom
            sorry for being a thicko, but do i need a dump from my Bios or can all these tools be ran on the laptop with the issue and get the data required. But im guessing i need to use the clip or get the soldering tools out if i need to fix my issues.
            when i last used the clip i dont recall getting the right results from the bios chip, just ordered a solder rework tookfor work so may have to give that a try.
            Thanks again for the replies
            The NiNja
            • hardware1
              • Sep 2021
              • 2943
              • N/A
              The NiNja
              You will need to take a backup from your BIOS and clean it yes.
              If you have the Original BIOS that will be much helpful.
              • Ginjaninja
                • Aug 2021
                • 13
                • United Kingdom
                Re: Recovered 850 G1 Bios now the warning machine not in committed state
                Unfortunately i think i lost my original backup when i updated my laptop to windows 11. to be fair i don't think the backup i took was good as probably why i knackered the bios up in the first place.
                so i am just waiting for the rework station to arrive, but when it does I'm assuming i need to de-solder the chip and plug into my programmer to get a dump of the back up as it is, then post on here to hope someone can clean it up for me. once i have a clean bios version i would just reprogram the chip with this and then re-solder back onto the board.
                Thanks again
                The NiNja
                • Ginjaninja
                  • Aug 2021
                  • 13
                  • United Kingdom
                  Good evening all
                  Got the rework station and going to desolder the chip from the HP Elitebook 850 G1.
                  A couple of things:
                  1. In the attached image is that the correct chip i need to remove.
                  2 is the CH341A programmer OK to read this chip.
                  then after i have read the chip do i just post here and hpoefully one of you guys can clean it up.
                  TIA
                  The NiNja
                  • hardware1
                    • Sep 2021
                    • 2943
                    • N/A
                    Good evening all
                    A couple of things:
                    TIA
                    The NiNja
                    Take a clear image for both chips, we need to see what's written on them.
                    • Ginjaninja
                      • Aug 2021
                      • 13
                      • United Kingdom
                      cant seem to get a close enough image with the camera but using a magnifying glass both chips appear to be the same
                      WINBOND
                      25Q128FVSG
                      1417
                      Does this correct
                      TIA
                      The NiNja
                      • hardware1
                        • Sep 2021
                        • 2943
                        • N/A
                        WINBOND
                        25Q128FVSG
                        1417
                        Does this correct
                        TIA
                        The NiNja
                        No, U366 is 2MB (16Mbit).
                        Upload the content of CN365 chip, the one you marked it by a circle (25Q128FVSG).
                        • Ginjaninja
                          • Aug 2021
                          • 13
                          • United Kingdom
                          here is the dump of my bios chip which is currently giving the message at start up "Waring: Machine Not in Committed State"
                          • hardware1
                            • Sep 2021
                            • 2943
                            • N/A
                            This file doesn't contain ME Region, so it can't be repaired.
                            I will attach a working BIOS which I have tried before, it's for 840 g1 but I can change the DMI for yours if the device works fine.
                            I found this Serial Number in your dump file "CNU4289M7D" it's correct or not?
                            • Ginjaninja
                              • Aug 2021
                              • 13
                              • United Kingdom
                              Hi Hardware1
                              i can confirm this is the serial number
                              Thanks Again
                              The NiNja
                              • Ginjaninja
                                • Aug 2021
                                • 13
                                • United Kingdom
                                Also before i write the bios file to the chip, do i erase the chip first or can i just write over the old bios data.
                                TIA
                                The NiNja
                                • hardware1
                                  • Sep 2021
                                  • 2943
                                  • N/A
                                  TIA
                                  The NiNja
                                  Yes, you should erase the chip before the writing process.
                                  If you are using NeoProgrammer software, you can check these 5 options and press on the "Write IC" icon and it will do everything automatically.
                                  • Ginjaninja
                                    • Aug 2021
                                    • 13
                                    • United Kingdom
                                    Does NeoProgrammer work with CH341a programmer
                                    The Ninja
                                    • hardware1
                                      • Sep 2021
                                      • 2943
                                      • N/A
                                      The Ninja
                                      Yes, it's the best software for CH341A (as far as I know).
                                      Download it from here:
                                      https://www.badcaps.net/forum/showpo...postcount=2374
                                      • Echoo
                                        • Apr 2018
                                        • 91
                                        • Budapest
                                        Good day!
                                        I have a "committed state" problem with my HP Elitebook 850 G1. Can anyone help me solve it?​
                                        HP Elitebook 850 G1
                                        SN: 5CG4363C75
                                        PN. J6V94EC#EBD
                                        MB. HSTNN-I11C-4
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • volinakis
                                          HP 830 G10 Bios Identity Data Recovered while unlocking
                                          by volinakis
                                          Hi, I need some help with HP EliteBook 830 G10
                                          S/N: 5CG3444X0X
                                          ProdID: 8Z5G7EC
                                          Can't find motherboard ID, SPS is N44544-601
                                          I am trying to unlock it, did all modifications in main bios to put it in MPM mode, after writing new bios at 1st boot it appears a message:
                                          "Bios Identity Data Recovered
                                          The Bios has recovered its identity data from Embedded Controller due to data mismatch"
                                          and it won't start in MPM Mode. Someone please help me to disable this "Bios Identity Data Recovery", I don't have a clue where it is.
                                          Attached...
                                          08-05-2024, 09:48 AM
