Lenovo L15 Gen 2 (Ryzen) Password removal w/ Vertyanov Successor
  • Atomsk
    • Oct 2022
    • 5
    Hi all. Thanks for taking the time to read. Here's the situation. I have several of this model, most locked. Recently purchased a Vertyanov Successor and was able to successfully read and write to the Nuvoton EC. However, erasing then writing did not remove the password. I was expecting to user the lenovoUone tool. I have an unlocked bios saved and was able to write that file. The Bios was no longer locked but the SN info etc was of course wrong. (proof of concept for me at least)
    I was hoping that if an unlocked version of my Bios was made for me, I could use that to compare and learn where to edit the password, assuming that is the was the way forward. If the solution is building a new bios and flashing the ec, could I have an unedited one and one with my SN added.
    Anyway, here is the pertinent info:
    Lenovo Thinkpad L15 Gen2
    Board NM-D391
    SN - PF-34YBPD
    EC- NPCE68BPA0DX
  • peste
    • Dec 2016
    • 12262
    • ROMANIA
    Re: Lenovo L15 Gen 2 (Ryzen) Password removal w/ Vertyanov Successor
    Board NM-D391
    SN - PF-34YBPD
    EC- NPCE68BPA0DX
    to understand that the password for this type of laptop is in the EC bios?..
    try this..
    • Atomsk
      • Oct 2022
      • 5
      Hey Peste, thanks for the file but that wasn't quite what I was looking for. That Bios was locked as well. Was it supposed to be unlocked? I'm assuming that the password is physically stored in the EC. I was hoping to look at my locked and unlocked bios and learn something. If I could get this unlocked, that would be a start.
      • volinakis
        • Jan 2021
        • 2626
        • N/A
        Board NM-D391
        SN - PF-34YBPD
        EC- NPCE68BPA0DX
        why don't you compare locked vs unlocked EC file? Post also unlocked file to compare them.
        • Atomsk
          • Oct 2022
          • 5
          I meant to say that the unlocked file was from a gen1 and I was able to unlock a different gen1 using that method. I do not have an unlocked L15 Gen2. In this thread: https://www.badcaps.net/forum/showthread.php?t=112184
          the block the password was stored in was found and could be erased. I'm hoping to find those addresses for this model.
        • skazide
          • Jul 2015
          • 142
          • morocco
          thanks maxpower3 , it only still one msg . no i dont have the original cause i did mistake with saving 256 not 384 kb and a guy provide me with this one from exract lenovo bios
          • Maxpower3
            Maxpower3 commented
            Editing a comment
            cool, things are better
            you have access to the setup now.
            post a photo of the numbers in the setup
            Rfid don't know yet but we will find
            Message: 0188: Invalid RFID Serialization Information Area. Solution: The EEPROM checksum is not correct (block # 0 and 1).
            The system board should be replaced ​​ ​
        • skazide
          • Jul 2015
          • 142
          • morocco
          ok bro
          • Maxpower3
            Maxpower3 commented
            Editing a comment
            you still have the file in 256??
        • skazide
          • Jul 2015
          • 142
          • morocco
          this is the file bro
          • Maxpower3
            Maxpower3 commented
            Editing a comment
            too bad the good part is missing
        • skazide
          • Jul 2015
          • 142
          • morocco
          if this prob is asset tag can this do the work ??
          • Maxpower3
            Maxpower3 commented
            Editing a comment
            I don't think so, it's not necessary.
            the problem is in UUID and Mac address
            you can dump eeprom with lenovo utility and post me the blocks in pictures
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1173
          • France
          one of the dumps is shifted, I need to read block 3,
          I'm going to give your information, I kept that of the donor​
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1173
            • France
            here is a block after password (block6/7), I don't know this function 0x5C600 and 0x5D600.
            Click image for larger version  Name:	lenovo-tp-yoga-x390-8365u-1624872577.jpg Views:	0 Size:	289.5 KB ID:	3166632
            I made a file with your mac address and changed UUID.
            you can try, I don't really believe it
            please before writing, look at the thread and post identical photos with yours
            https://www.badcaps.net/forum/troubl...31#post3157831
            or try initialise eeprom with utility (4) and rewrite your serial and others informations
            Click image for larger version  Name:	365460347_1024433032120292_6689861109918884261_n.jpg Views:	0 Size:	468.1 KB ID:	3166651
            • skazide
              • Jul 2015
              • 142
              • morocco
              😁😁 THE LAST one is better
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                post picture serial setup please
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                if 2 times RFID + product name, we are in the right place
            • skazide
              • Jul 2015
              • 142
              • morocco
              it is not asset tag , im thinking to just let it like that
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                put back the one from before and do an initialization with utility to rewrite the checksum
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1173
              • France
              Initialise configuration aéra
              should be enough to clean block with uuid and mac address and product name
              • skazide
                • Jul 2015
                • 142
                • morocco
                ini untility i never used is this a programe software
              • Atomsk
                • Oct 2022
                • 5
                Thanks Maxpower3, those were it. Bios unlocked! For everyone else..
                DMI information and password writes 2 times on file
                Dmi start from 0x5C120 and 0x5D120
                Password 0x5C420 to 0x5C56F and 0x5D420 to 0x5D56F​
              • wuyaping
                • Jun 2022
                • 20
                • china
                Hi! Can you share this .EFI file with me?(This associative maintenance utility you have is not quite the same as the one I have)😀
                • jozlar
                  • Mar 2022
                  • 59
                  • tbilisi
                  PLEASE UNLOCK BIOS
                  THINKPAD L15 GEN 2
                  SERIAL: PF-3MSSHS
                  TYPE : 20X4-S2VJ00
                  FACTORY ID : JVHFC1
                  • Vesko356
                    Vesko356 commented
                    Editing a comment
                    Do NOT post in all caps please!
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1173
                  • France
                  Visitor message from jozlar
                  jozlar posted a Visitor Message for Maxpower3
                  Yesterday, 01:05 PM
                  please help me l15 gen 2 unlock
                  • jozlar
                    • Mar 2022
                    • 59
                    • tbilisi
                    Yesterday, 01:05 PM
                    I can't understand these addresses, I'm using hex editor, is another editor needed?
