HP 840 G8 Bios Unlock
thisAttached FilesPremium supporters get full download access and other benefits.
HI i need help with my hp 840 g8 witch don't know all usb device
SN:5CG2127ZKZ
hi can someone help me fix my bios files i think its the ec that have errors
sn 5cg23041s3Attached FilesPremium supporters get full download access and other benefits.
Hello, I have this HP Elitebook 840 G8
could you help me?
Model: HP EliteBook 840 G8
S/N: 5CG213412K
Board-Model:6050A3426501-MB-A02
ProdID: 3E9K6UP#ABA
Chip-model: Winbond 25Q256JVENAttached FilesPremium supporters get full download access and other benefits.
tryAttached FilesPremium supporters get full download access and other benefits.
The result is the same; after running the sent file through ME Analyzer, it is still in the "Initialized" state. I started over from my original main dump and replaced the Intel ME, PMC, and PCHC sections. CSE ME Version 15.0.42.2235 -> 15.0.55.2751 PMC Version 150.1.20.1041 -> 150.1.20.1042 PCHC Version 15.0.0.1021 -> 15.0.0.1021
After restarting, the NVME drive was no longer detected, and upon the next reboot, the PC failed to start entirely. I therefore reflashed the main BIOS.
I managed to restart again, though a few error windows appeared. Thinking I could improve the situation, I updated the BIOS via a USB flash drive using the latest version found on the HP website. All the update steps completed successfully, and then the PC shut down but could not be restarted. I should mention that I had not yet reconnected the battery.
I am attaching the two ME Analyzer files; there may be a compatibility issue with the downloaded versions.
Best regards,
S/N: 5CG21032H3
After several unsuccessful attempts, maybe I should start from a Matched Dump?
My motherboard is: CORVETTE-6050A32175101-MB-A01 (A1)
S/N: 5CG21032H3
Could you please help me?
Best regards,
HI!
BIOS PASSW problem. Unlock please!
HP 840 G8 sn: 5CG2094MB1
MB: 6050A3217501-MB-A01(A1)
PRODID: 26D60AV
THX!Attached FilesPremium supporters get full download access and other benefits.
try..Attached FilesPremium supporters get full download access and other benefits.
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
It only takes 1 minute:
https://www.badcaps.net/settings/subscriptionsComment
try this and feedback
post S/N, full name and model, motherboard model,.product number,etc.WHERE CAN I GET HP 840 G8 Bios FILES MAIN AND EC TESTED
post the contents of the bios chip even if it is corrupted..
hi need bios files main bin and ec bin
Hp elitebook 840 g8
s/n: 5CG2061L2M
ProdID:516G7UC#ABA
MOTHERBOARD MODEL:CORVETTE-6050A3217501-MB-A01(A1)
MY BIOS FILES
try ,only ECAttached FilesPremium supporters get full download access and other benefits.
Re: HP 840 G8 Bios Unlock
Please help to unlock 840 G8Attached FilesPremium supporters get full download access and other benefits.
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by bad0menzI wanted to remove the BIOS password on my Omen 16, so I used a ch314a to flash a modified BIOS file. Based on readings, the chip seems to have been programmed correctly, however the computer won't POST or boot—no fan, and either the power button blinks 1 long 1 short, or the capslock blinks once before shutting off.
There shouldn't be any shorts or physical damage from what I can tell
This Omen probably has HP SureStart Gen4, a firmware-level security feature embedded in the BIOS, however I've been told that "just by flashing to the dedicated flash there should... -
by TrademarkHello everyone,
I’m hoping someone can help me locate a verified original BIOS dump for my Acer laptop.
This is NOT a BIOS password removal request.
I’m looking for an original 32MB SPI BIOS dump to use as a reference in case my BIOS firmware is corrupted. My plan is to first dump and back up my own BIOS as soon as my programmer arrives. I am not planning to blindly flash someone else’s BIOS.
Laptop Information- Model: Acer Predator Triton 16 PT16-51-99GL
- Motherboard: DA0ZQDMB8AE Rev. E
- Main SPI flash: Winbond W25Q256JVEN (32MB)
- Secondary
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
- Loading...
