i need a help unlock 645 g9
Hi I need Help to remove password on HP EliteBook 645 G9, S/N 5CD243HVQQ. I have uploaded both ec and main bios.
Thank youAttached FilesComment
I noticed there's a lot of unlock request for this model HP EliteBook 645/655 14/15.6 inch G9
The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you shouldFlash Both.
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
use BCU and put your original DMI
This bios is extracted from hp website so its fast boot this would work in two models 14 and 15 inch they have the same bios.
To determine your BID use any hex editor and search for the BID. Ex: U77
frequently asked questions:
can i use this to my HP EliteBook 645/655 14/15.6 inch G9- yes
This is the both BID U77 and U87 its all you need.Comment
Channel: BIOS Requests ONLY!
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by BlackVisorRedmiBook Pro 1542022 6800H
SKU: TM2113-39463
Model Number: RMA2204-AB
CMIIT ID: 2022AP1835
SN: 39463/22WD01355
BIOS version: RMARB5B0P1010 20230628
1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...-
01-14-2024, 06:35 AM -
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by RMDUiFTGood day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
I have a few questions:- If I would buy this laptop and have
- Loading...
