Lenovo thinkpad t14s gen 2 need bios bin
Actually, I went too fast and forgot the second file... my bad
Attached FilesPremium supporters get full download access and other benefits.
Try this file (I've injected the BIOS region into your file as requested)
Open the .FL1 file with HxD, go to the start of the file, and select 0x320 bytes (hexadecimal) and delete that block
Then go to offset 0x1000000 and delete everything from there onward. What's left is the BIOS region that should be injected into the backup of the Giga chip at offset 0x1000000Attached FilesPremium supporters get full download access and other benefits.
Try flashing both files from Post #'11 > https://www.badcaps.net/forum/troubl...81#post3852681Hi,
Thanks Sparo for the bios file and explanation about .fl1 file
Unfortunaly after re-flashing the BIOS file you provided, the LED on the Lenovo cover flashes when I plug in the charger, the battery LED stays on, but the PC won't start up anymore.
There's also an image that shows which file belongs to which chip. Good Luck!Comment
Even if my BIOS settings aren't in the same place as the one circled in red and green ?
In that case, make another backup of the other chip in case you haven't flashed it yet
and then flash both chips using this file combination
(t14sg2i)WinKey/1320000-132FFFFAttached FilesPremium supporters get full download access and other benefits.
Nothing works; the problem must be somewhere else... We replaced the power button, but the issue remains the same.
Thanks anyway for your time.Comment
Hi Everyone.
I need a godd bios to this board please.
Lenovo T14s Gen 2 that is reacting to power button but after 5 second of fan spin and then it turns off.
It consumes about 360millamps when starts.
It charges the battery fine
S/N: PC2JY4M1
Type: 20WN
Board ID: NM-D362 Rev 2
tryHi Everyone.
S/N: PC2JY4M1
Type: 20WN
Board ID: NM-D362 Rev 2Attached FilesPremium supporters get full download access and other benefits.
Hi, try again with this BIOS file and see what happens
Lenovo T14s Gen 2 (Type 20WM, 20WN) Laptop (ThinkPad) - Type 20WN
Lenovo ThinkPad X13 Gen 2 (Type 20WK, 20WL)
Machine Type Model 20WNS15016
BIOS Version 1.63 (N35ET63W)
hi,
seems I've posted in the wrong thread. sorry for that. please see my quoted post with attachments:
https://www.badcaps.net/forum/troubl...46#post3871146Originally posted by Cai-pirinhahi, T14s Gen 2, NM-D362 Rev. 3.0, S/N PC-2CZPL5, 20WM00A6GE
firmware corrupt after update, doesn't boot. I''ve been trying to reconstruct the firmware using FIT, using the original GBE and BIOS regions and the clean ME from lenovo ME update N34RG18W. I almost made it, OS will boot and run properly with wifi etc, but second USB port (the one on the USB IO board) won't work, reporting over current protection as soon as device plugged in. in FIT i can't find the error and I'm lost right now.
I've attached the original dump of U2201, U2202 and my attempt to recrate a working firmware. maybe someone can tell me what has to be changed for the second usb port to work properly, many thanks in advance!
thanks a lot in advance!Comment
No change. Is my EC firmware corrupt?Comment
It's possible, but these MEC1503 ECs are a bit tough to deal with for now
> Guide to transplant MEC1503 EC chip and EEPROM reprogamming for T14s gen 2 and X13 gen 2Comment
THANKS
by markvtechHello Badcaps community,
I am requesting assistance rebuilding a corrupted BIOS binary for a ThinkPad T14s Gen 1 AMD.
System Specifications:- Laptop Model: Lenovo ThinkPad T14s Gen 1 (AMD)
- Type / Machine Type Model: 20UH-001AUK
- Serial Number: PC-1NKWLA
- SPI Flash Chip: Winbond 25Q128JWSQ (1.8V, 16MB)
Problem Description: The system fails POST. When pressing the power button, the power LED turns on, the keyboard backlight flashes once and turns off, but there is no display, no Caps Lock LED response and no fan (although sometimes comes on after 10min if left...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
This specification for the Lenovo ThinkPad T14s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T14s boardview and T14s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-07-2024, 07:20 AM
- Loading...
