HP ProBook 440 G9 need bios + ec
  • danito
    • Jun 2016
    • 1054
    • Romania
    #101
    Originally posted by zedxx7
    Hello everyone, could you help me remove the password
    hp probook 440 g9
    board DAX8SFMB8B1 REV B
    sn\ 5CD3376PB1
    Try
    • zedxx7
      • Feb 2018
      • 25
      • ALMANYA
      #102
      Originally posted by danito
      Try
      The password screen still comes up. It didn't work.
      • zedxx7
        • Feb 2018
        • 25
        • ALMANYA
        #103
        hp probook 440 g9
        sn\ 5CD3376PB1
        The password screen is still coming up, can you help me please?
        • ghedada.06
          • Feb 2023
          • 22
          • Algeria
          #104
          hi, i lost the original bios of my hp probook 440 g9 i still have the EC firmware only. can anyone help me please create a new bios file
          here is dmi info from ticket on my laptop
          HP ProBook 440 G9
          Prod ID 6A293EA#ABF
          CT: RPYUP7FA1GY5VW
          SN# 5CD23178HV
          build ID 22WWRTCZ601#SABF#DABF
          476J6S6b7B7J7M7Q7WsaBapaqauawbUbhcAfPguk8mEmwn7nVnwpTpnpqprqjqz.tf
          • ingenieroedu
            • May 2023
            • 73
            • Colombia
            #105
            Hi everyone, could you help me remove the BIOS password and disable Absolute?
            HP ProBook 449 g9
            Motherboard model: DAX8SFMB8B1 REV B
            Serial number: 5CD4076Y4B​
          • bobans1983
            • Jun 2015
            • 10
            • sdtb ghn
            #106
            Unlock please 440 g9
            sn# 5CD228DGTQ
            prod id # 6Q8G4ES#UUW
            • rex98
              • Feb 2023
              • 1287
              • Mandaue CEBU, Philippines
              #107
              I noticed there's a lot of unlock request for this model HP ProBook 440/450 15.6/14 inch G9
              The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both!
              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
              use BCU and put your original DMI
              This bios is extracted from hp website so its fast boot this would work in 2 models 14 and 15.6 inch they have the same bios.
              To determine your BID use any hex editor and search for the BID. Ex: U72
              frequently asked questions:
              can i use this to my HP ProBook 440/450 15.6/14 inch G9- yes
              This is the both BID U72 and U85 its all you need.​
              To determine your original DMI use my DMI tool:​ https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
              • lenain31
                • Aug 2025
                • 7
                • France
                #108
                Bonjour,
                j'ai voulu aller plus vite que la musique en faisant une sauvegarde du BIOS SPI et ROMEC. Résultat : j'ai perdu tout le programme de mon ECROM. Serait-il possible d'avoir un fichier ou c'est foutu ?
                ci-joint fichier bios avec password
                -carte mère ref DA0X8SMB8H1 REV:H
                -HP PROBOOK 440 G9
                -SN#5CD223D2BK
                -PROD ID 6J3K6EC#ABF
                I wanted to get ahead of the game by backing up the SPI and ROMEC BIOS. As a result, I lost my entire ECROM program. Would it be possible to get a file, or is it ruined?
                Attached is the BIOS file with password.
                -Motherboard ref. DA0X8SMB8H1 REV:H
                -HP PROBOOK 440 G9
                -SN#5CD223D2BK
                in English please...
              • lenain31
                • Aug 2025
                • 7
                • France
                #109
                thank you but
                I can't tell if it's U72 or U85
                  • 21586
                  Originally posted by lenain31
                  thank you but
                  HxD hex editor - https://mh-nexus.de/en/hxd/
                  • lenain31
                    • Aug 2025
                    • 7
                    • France
                    #111
                    thank you very mutch
                    • lenain31
                      • Aug 2025
                      • 7
                      • France
                      #112
                      Hello, so I tried reflashing the EC and did a read test via the CH341A and ASPROGEAMMER. Everything is fine. Soldering on the motherboard. The light flashes orange endlessly. The PC won't turn on. I unsoldered it and did a read test. Nothing on the EC model Gigadevice 25B255EY1G.
                      Do I have to write the FFs in the software or not?
                      Can I lock the memory after writing?
                      Thanks for your help.
                        SMDFlea commented
                        Editing a comment
                        erase the chip before programming
                    • lenain31
                      • Aug 2025
                      • 7
                      • France
                      #113
                      Ok, Do I have to write with the FFs in the EC or not?
                      • elkhiyhie
                        • Jun 2020
                        • 35
                        • philippines
                        #114
                        absolute persistent - solved..
                        company locked via internet set up - do i need to clean EC firmware?
                        • elkhiyhie
                          • Jun 2020
                          • 35
                          • philippines
                          #115
                          Guys, please help me with Absolute and MDM I already tried doing it, the MDM was removed because there was no serial, and I already deactivated Absolute and installed Windows 10, but I can’t get the DMI tool to work.. please fix the bin file on your side that I tried.. thank you
                          SN: 5CD 2315 517
                          • danito
                            • Jun 2016
                            • 1054
                            • Romania
                            #116
                            SN: 5CD 2315 517
                            read post # 107
                            • elkhiyhie
                              • Jun 2020
                              • 35
                              • philippines
                              #117
                              read post # 107
                              I can’t get the DMI tool to work or install, it keeps auto-hiding. Please just help me with my DMI info, brother.
                              [QUOTE=danito;n3718859]
                              i follow the instruction
                              • elkhiyhie
                                • Jun 2020
                                • 35
                                • philippines
                                #118
                                read post # 107
                                where i can find CT Nu,mber?
                                • elkhiyhie
                                  • Jun 2020
                                  • 35
                                  • philippines
                                  #119
                                  all goods ,,, my problem is fingerprint , i tried to install from hp and google it wont work..
                                  can someone send the right installer or steps on how you fix the fingerprint to work?
                                  • xander007
                                    • Jan 2017
                                    • 18
                                    • Украина
                                    #120
                                    in your old bios. use BADCAPS HP DMI TOOL
                                    • studdy05
                                      Bricked HP Probook 450 G7 Bios questions
                                      by studdy05
                                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                      Ive got...
                                      07-08-2025, 09:24 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • the_raz
                                      Need (unlocked) bios for HP Probook 450 G3 Notebook
                                      by the_raz
                                      I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                      Laptop number 1:
                                      Model: HP ProBook 450 G3
                                      Motherboard part number:...
                                      12-17-2024, 03:37 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
