Dell latitude 3190 Suffix E7A8 Bios Password Request
    Re: Dell latitude 3190 Suffix E7A8 Bios Password Request
    laptop will go MPM
    just put service tag into setup
    restart and Alt + F
      Originally posted by dycc View Post
      laptop will go MPM
      restart and Alt + F
      Exactly, due to the wrong unlocking procedure. In addition to the lack of service tag, there are more problems.
        It doesn`t really matter to most they just want a working laptop.If its out of warranty anyway it doesn`t matter,and you can check for updates manually at the website.
        If you copy the dell variable to a new bios region the pass is still there,modifying a part or parts of the variable in some way is needed to keep the service tag,key etc.For a bios that has no pass but just needs fixing this is the way to keep all info,by copying the dell variable DVAR.
          what is the problem if i can manually enter SERVICE TAG into setup and keep my windows Licence ???????
          show us your CORRECT method
            You're right, maybe the important thing is just unlocking, quality doesn't matter for most.
              All 8FC8 family, 8 or 32 Mb, to unlock properly without any data loss, only one byte needs to be modified with any disassembler.
                Sometimes the key is gone https://www.badcaps.net/forum/showthread.php?t=92597
                  i know this Byte when Absolute (computrace ) is activated
                    The calculator is public, it's here in the beta version to calculate the suffix E7A8 beta version for all public. https://beta.bios-pw.org/
                    It worked correctly for a Latitude 7390 2-in-1, I looked in several forums but I only found asking to buy
                      @tiagotecno
                      It has been released just a few weeks ago, still beta though, but working, soon to be put into main domain.
                        Hello!
                        Can ANYONE please help with unlock code for 65FDQN2-E7A8 ?
                        Thanks a LOT.
                          @ctebke (this thread is for Latitude 3190)
                          For anyone else reading this post, this E7A8 suffix generator has been released recently, you may generate the master passwords yourself at https://beta.bios-pw.org/, just having in mind that these passwords are calculated for a US QWERTY keyboard layout and if you have a QWERTZ or AZERTY keyboard you may need to do the proper conversion, or better yet, use a picture of a US QWERTY keyboard for key placement.
                          Other thing to consider is the "Open Bracket '['" key placement, this key is always at the RIGHT of P in a US QWERTY keyboard layout.
                          Precision 5520
                          65FDQN2-E7A8
                          Country: Germany (use US QWERTY keyboard or just exchange every Y for Z and Z for Y in master password)
                          Instructions:
                          - Type master password, use NATO phonetic guide under password.
                          - Press and hold down CTRL key followed by ENTER key twice (CTRL-ENTER-ENTER).
                          - If password #1 does not work proceed with password #2. Give them a few tries each each before saying it didn't work.
                          NOTE: Sometimes if using master password within Setup/BIOS, just pressing ENTER after typing password will do.
                          1-----------
                          DELL Service Tag: 65FDQN2-E7A8
                          password: zxdIkZ1XBrINbkDr
                          z - zulu ( lowercase )
                          x - x-ray ( lowercase )
                          d - delta ( lowercase )
                          I - INDIA ( UPPERCASE )
                          k - kilo ( lowercase )
                          Z - ZULU ( UPPERCASE )
                          1 - 1 ( digit )
                          X - X-RAY ( UPPERCASE )
                          B - BRAVO ( UPPERCASE )
                          r - romeo ( lowercase )
                          N - NOVEMBER ( UPPERCASE )
                          b - bravo ( lowercase )
                          D - DELTA ( UPPERCASE )
                          2-----------
                          password: a0ycrkLr9Be8BZze
                          a - alfa ( lowercase )
                          0 - zero ( digit )
                          y - yankee ( lowercase )
                          c - charlie ( lowercase )
                          L - LIMA ( UPPERCASE )
                          9 - 9 ( digit )
                          e - echo ( lowercase )
                          8 - 8 ( digit )
                            It works, Thanks a LOT.
                              please read post #202 .
                                Dell Latitude 3190 LA-F463 Bios
                                Dell Latitude 3190 has bios password, can anyone assist? Here is my dump. Thank you
                                  Re: Dell Latitude 3190 LA-F463 Bios
                                  If the suffix is E7A8 read post #152 ,the area highlighted in red
                                    Thank you, it worked!
                                      I am trying to obtain a bios password from bios-psw.org but no results, can anybody help.
                                      system number: B0ZLLC2-E7A8
                                      is there any alternative link or software to obtain the password?
                                      Regards
                                        Regards
                                        I3kj82GxnZUGZa2m
                                        ejX9Q2EMz6zLM494
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
                                          Regards
                                          read post # 152
