HP Elitebook 850 G5 COMPUTRO-6050A******-MB-A01(A1)
  • Dhaka Lab
    • Nov 2020
    • 29
    • Bangladesh
    HP Elitebook 850 G5 COMPUTRO-6050A3079801-MB-A01(A1)
    please clean me bios. late display
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: HP Elitebook 850 G5 COMPUTRO-6050A3079801-MB-A01(A1)
    Have you tried doing it yourself?
    There are detailed instructions in this thread ---> ME Firmware Cleaning Guide.
    Become a Badcaps supporter
    Thanks to all supporters.
    • Dhaka Lab
      • Nov 2020
      • 29
      • Bangladesh
      pls clean security device problem message remove.
      please can anyone help me?
      • JersonP
        • Mar 2020
        • 30
        • mozambique
        clean-me pleace
          • 22096
          Originally posted by JersonP
          clean-me pleace
          You must post the serial number,and try the available HP unlocking software posted in the forum, RCUnlocker
          You MUST:
          Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
          • vivaitimbii
            • Feb 2019
            • 16
            • malaysia
            OK
            • laptopsolution
              • Nov 2016
              • pakistan
              100% working test my shop
              • nesredin
                • Feb 2018
                • 39
                • ethiopia
                hello there.. i have 850 g5 and someone erase both main and ec file.
                and i found working bios in the site everything is perfect but it shows endpoint security error
              • shadow666
                • May 2017
                • 115
                • UAE
                MB : 6050A2930901-MB-A01
                Elitebook 850 G5
                ProID : 2FH29AV
                SN : 5CG84535ZJ
                i have a Elitebook 850 G4 Won,t boot Backup Original bios and clear me region and program original bios boot up is ok but after 40 second while !
                i tested by another bios clear me and program by rt809h and won,t fix , after 40 second boot up
                What do you guys think is the problem? Has anyone had any experience with this?​
                i attached backup bios
                Regards
                • peste
                  peste commented
                  Editing a comment
                  post moved..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              • hoaca388
                Badcaps
                • Jan 2022
                • 12406
                Elitebook 850 G5
                ProID : 2FH29AV
                SN : 5CG84535ZJ
                Regards
                Try
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • STKR123
                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                  by STKR123
                  Greetings badcaps community,
                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                  I learned that desoldering...
                  10-29-2024, 06:03 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Guest
                  Elitebook 850 G5 BIOS bricked
                  by Guest
                  I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                  I assume the BIOS update failed, so I searched for the BIOS chip.
                  I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                  However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                  Can the corrupted...
                  03-24-2025, 01:21 AM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
