Lenovo Thinkpad E490 Bios Dump
  • max_sneka2
    • Mar 2022
    • 81
    • iraq
    Hello EveryOne ...
    I need Bios dump for Lenovo Thinkpad E490
    Board Number FE490/FE590/FE480
    NM-B911
    REV :1.0
    TYPE 20N8-0057AD
    S/N PF-1RP5F6
    And Here is Old Dump
  • hardware1
    • Sep 2021
    • 2943
    • N/A
    Re: Lenovo Thinkpad E490 Bios Dump
    Originally posted by max_sneka2
    Hello EveryOne ...
    NM-B911
    REV :1.0
    TYPE 20N8-0057AD
    S/N PF-1RP5F6
    Here's your New BIOS, try it and let me know.
    all donations are welcome,
    • max_sneka2
      • Mar 2022
      • 81
      • iraq
      It's Working Fine ... Thank You Man You saved me
      • hardware1
        • Sep 2021
        • 2943
        • N/A
        Good to know, You're Welcome.
        • dihcar84
          • Aug 2012
          • 199
          • morocco
          can you help me with my E490 COMPUTRACE ENABLE
          • hirens
            • May 2022
            • 189
            • uganda
            hey guyz
            i have a lenovo E490 that needs a new bios file
            it powers on well the screen becomes black but the image dosenot show
            after a while the fun runs.
            board number: fe490/fe590/fe480 nm-b911
            the sticker with serial number is not clear to view
            thats the best info i can provide
            help guyz
            • 29biosbricked
              • Jun 2025
              • 6
              • Japan
              Hello everyone!
              I need a bios file for my thinkpad e490 due to a corrupted bios issue caused by resetting nvram in opencore.
              Laptop Model: Lenovo ThinkPad E490 20N9
              Board Number: FE490/FE590/FE480 NM-B911
              REV: 2.0
              Bios Chip: Winbond 25Q128JVSQ
              Type: 20N9-000DPH
              S/N: PF-1DHTNJ
              CPU: I7-8565U WhiskeyLake (cpu chip numbers: V930D444, SRFFW, 04899)
              dGPU: AMD RX 550X (gpu chip numbers: M8CH5.00, 216-0905004)
              It was working perfectly fine before I reset the NVRAM in opencore boot menu.
              Laptop turns on, powerbutton light and capslock light on, but no display.
              Thank you!
              • peste
                peste commented
                Editing a comment
                post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
            • peste
              • Dec 2016
              • 13199
              • ROMANIA
              Originally posted by 29biosbricked
              Hello everyone!
              REV: 2.0
              Type: 20N9-000DPH
              S/N: PF-1DHTNJ
              Thank you!
              post the contents of the bios chip even if it is corrupted..
              • 29biosbricked
                • Jun 2025
                • 6
                • Japan
                Device: Laptop
                Brand: Lenovo
                Board number: FE490/FE590/FE480 NM-B911, REV 2.0
                S/N: PF-1DHTNJ
                BIOS Chip: Winbond 25Q128JVSQ
                Issue: After resetting NVRAM in OpenCore boot menu, device no longer displays. Power button and capslock light is lit, but no display of any kind. It was working before reset NVRAM.
                Request: BIOS Repair
                attached is the corrupted bios file​
                • arkontzr
                  • Jul 2025
                  • 5
                  • United Arab Emirates
                  Hi everyone, I've read all the threads before posting, and apologize beforehand for the whole history I'll tell, I just truly hope this amazing community can help me fix my problem.
                  My BIOS gets corrupted after NVRAM reset on Open Core, I bought the CH341A, made a backup of my dump, and tried to flash with several of the different BIOS posted here, with all of them, I was having the same result:
                  Power light turns on and off slowly 3 times before staying steady on, no caps locks/tab working, which of course made me settle my mind on think that I burned my motherboard on the process, I leave the laptop "on" overnight blisfully hoping it will work at morning, of course it didnt; HOWEVER, after I pressed the power button to turn it off, it goes through some sort of "reset" where out of nowhere it turn ON! It shows me the lenovo boot, of course show me a CMS error and date/hour wrong, I go inside the BIOS Setup, reset all the values by default, restart, and the same BIOS error was showing, CMS & wrong date/hour, I fix the hour and date, restart, and GO BACK TO SQUARE ONE (Power light turns on and off slowly 3 times before staying steady on, etc).
                  My first thought was "Ok, let's see my corrupted backup BIOS and compare" But when I opened that file, it was full of FF codes, so either I didn't backup properly or it was not reading the chip at the moment I tried to do the backup.
                  So I would like to ask you guys what's the best option/solution I should go for it? I thought of buying a fully working and used E490 just to flash their working bios onto mine, but I feel that's basically what I've been trying to do when I flashed the files on this forum.
                  Thank you so much for taking the time to read and any help/comment will be fully appreciated!
                  Specs:
                  Thinkpad E490
                  Board Number FE490 NS-B911 Rev: 1.0 2018-10-25
                  BIOS Chip: Winbond 25Q128JVSQ 1912
                  Type 20N8-000GAD
                  S/N: PF-1RER6W 19/06
                  I'll leave attached the BIOS file that's currently flashed. I can also upload my backup, but it will be worthless since it's just filled with FF codes.
                    SMDFlea commented
                    Editing a comment
                    Thread merged.
                • skyline_bogota
                  • Sep 2022
                  • 26
                  • colombia
                  Hello I Need The Bios For The Leonovo Thinkpad E490
                  nmb911
                  TYPE 20N9-S01W00
                  S/N PF-26N5VA
                  I leave the original file
                    Lenovo ThinkPad E490 Notebook E Specification for Upgrade or Repair
                    This specification for the Lenovo ThinkPad E490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E490 boardview and E490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                    09-06-2024, 02:28 PM
