nm-d352
  • biosedit
    • Sep 2018
    • 60
    • Pakistan
    nm-d352
    HT4B0/HP4B0/HT5B1/HP5B1/HT 4B2
    NM-D352
    Bios need no display
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: nm-d352
    NM-D352
    Upload your Original Backup, write your Device Model Number and Serial Number.
    all donations are welcome,
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      Re: nm-d352
      TRY
      • hoaca388
        Badcaps
        • Jan 2022
        • 12423
        Re: nm-d352
        Originally posted by aboumohamed
        TRY
        Brand, model , serial ?
        • trepachka
          • Oct 2022
          • 457
          Hello, I have this Thinkpad T15 Gen 2 with booting issues. Upon start, the keyboard lights up briefly, fan spins and the CPU gets really warm. Then, it may take up to 6-7 minutes for the display to appear but then computer freezes shortly after and has to be restarted.
          I have another identical working board and I transferred the contents of both bios chips located around the memory slot from this motherboard to the one I am having the problem with. However, the power button does not even light up.
          I reflashed both chips using the original bins and the computer again acts as before.
          I am asking if someone can take a look at both bin files and have them fixed. I do not know which bios chip is needed, so I have included both.
          Thinkpad T15 Gen 2
          NM-D352 Rev. 2
          S/N PF3HPTSZ
          Type 20W4-00K2US
          Thank you.
          • trepachka
            • Oct 2022
            • 457
            Bump, could someone help me? I am not sure why this motherboard is not taking bios from other similar boards.
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              try
              • shiyab
                • Sep 2023
                • 1674
                • india
                NM-D352
                NEED OLDE BIOS &SNID
                • trepachka
                  • Oct 2022
                  • 457
                  Hey qayyum786,
                  this bin file you provided, for which bios chip? I have 2 bios chips sitting around the memory slot. Both chips are 256Mb
                  • shiyab
                    • Sep 2023
                    • 1674
                    • india
                    Hey qayyum786,
                    2 chip backup bios need
                    snid
                    • shiyab
                      • Sep 2023
                      • 1674
                      • india
                      Hey qayyum786,
                      32 MB NEED & SNID
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      Hey qayyum786,
                      I fix your bios in the morning from my home now i am on my office so i was not remember
                      BTW your main bios i clean again and post here so download from here and flash CHIP_BELOW_RAM_TEST_CLEAN
                      try
                      • trepachka
                        • Oct 2022
                        • 457
                        Ok, I reflashed the chip using your bin and I am getting the same result. The keyboard lights up briefly, the fan starts spinning, I get about 0.9A current draw and the CPU gets warm but no post.
                        I noticed 3.3V on the bios chip fluctuates, not stable. Meaning, it goes up and down between 1.5V and 3.3V. This may be the issue and the reason the computer is not posting. All other voltages are there. Even the other bios chip gets a steady 3.3V.
                        Without the schematics, it is hard to figure out the culprit.
                        • Fighter
                          Veteran Member
                          • Jul 2017
                          • 40
                          • Pakistan
                          Need Help With No Display
                          Lenovo Thinkpad T14 Gen2
                          Part # NM-D352 Rev 1.0
                          Serial # PF-3CV5GM
                          Both file Attached Display Issue Thanx In Advance
                          • rex98
                            • Feb 2023
                            • 1297
                            • Mandaue CEBU, Philippines
                            Serial # PF-3CV5GM
                            try only flash the main bios the outimage.
                            • Fighter
                              Veteran Member
                              • Jul 2017
                              • 40
                              • Pakistan
                              No luck bro same status fan spinning fast but no Display......
                              • Fighter
                                Veteran Member
                                • Jul 2017
                                • 40
                                • Pakistan
                                Anyone need Help Please !
                                • qayyum786
                                  • Aug 2018
                                  • 1959
                                  • INDIA
                                  S.N:- PF3CV5GM
                                  Try a new one
                                  • shiyab
                                    • Sep 2023
                                    • 1674
                                    • india
                                    Serial # PF-3CV5GM
                                    TRY
                                    • Kalman27
                                      • Jul 2021
                                      • 41
                                      • North Yorkshire
                                      Hello guys,
                                      Not sure if I need to start a new thread or if is it okay here.
                                      The problem is the laptop turns on, blank screen and after a few minutes it restarts. I think the BIOS update failed.
                                      I'm looking for a BIOS for a Lenovo ThinkPad T15 Gen 2 Type 20W4, SN: PF-368T34, the motherboard is HT4B0 / HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D351 Rev:1.0.
                                      If somebody could help that would be great.
                                      Many thanks
                                      • peste
                                        peste commented
                                        Editing a comment
                                        post the bios even if it is corrupted..
                                    • brasil
                                      bios lenovo thinkpad T14 Gen 2 logo
                                      by brasil
                                      Good afternoon, I have a lenovo thinkpad t14 gen 2 board model HT4B0/HP4B0/HT5B1/HP5B1/HT4B2
                                      NM-D352 REV: 2.0
                                      that has a company logo when I turn it on, I would like to remove it and have it turn on again with the lenovo logo appearing.
                                      HERE ARE THE BACKUPS OF THE ORIGINAL FILES, IF ANYONE CAN HELP THANK YOU VERY MUCH....
                                      04-13-2023, 11:10 AM
                                    • Whale linguini
                                      p14s Gen 2 thunderbolt eeprom dump
                                      by Whale linguini
                                      P14s Gen 2
                                      HT4B0/HP4B0/HT5B1/HT4B2
                                      NM-D352 Rev 1.0
                                      sn PF-35P15W
                                      Requesting thunderbolt dump
                                      also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                      09-03-2024, 01:56 PM
                                    • Whale linguini
                                      by Whale linguini
                                      I have a p14s gen2 board says
                                      NM-D352 Rev 1.0
                                      I need to flash the thunderbolt eeprom, laptop now fails to charge or power on. Can anyone confirm the IC? I think it is u6701 but I cannot read the chip (read the text on the top I mean). I don't see anything else that really looks like it would be it.
                                      Could anyone help me out if this is the correct one? I am new and still learning some so I wanted to be sure.
                                      Thank you!
                                      08-26-2024, 07:24 AM
                                    • Marco_compucell
                                      Thinkpad P15s Gen 2 Error 2203 System configuration is invalid
                                      by Marco_compucell
                                      Gooday
                                      I have an Lenovo ThinkPad P15s gen2 that keeps giving me this error 2203
                                      I have used the Lenovo Gold Key U1 Tool erased the eeprom and enter all the configs again but I still receive this error
                                      I believe it to be an BIOS problem
                                      I will Attach bios dump and some screen shots
                                      Board number: HT4B0 /HP4B0 /HT5B1 /HT4B2 NM-D352 Rev 2.0
                                      SN: PF-3R33ZC
                                      Type Number: 20W7-S2L700...
                                      04-26-2024, 02:32 AM
                                    • Tribalus43
                                      Lenovo Thinkpad T14 gen 2 intel schematics/boardview
                                      by Tribalus43
                                      Request: Lenovo ThinkPad T14 Gen 2 (Intel) Schematics/Boardview
                                      I’m looking for the schematics or boardview for a Lenovo ThinkPad T14 Gen 2 (Intel) with the following board:
                                      HT4B07HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D352 Rev: 2.0
                                      I’m currently dealing with some startup issues and would like to test for shorts. Any help would be greatly appreciated.
                                      Thanks!
                                      09-01-2025, 12:10 PM
