Need asus S430F bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    Originally posted by mrgame
    backup
    You must WRITEDOWN SERIAL NUMBER .
    • mrgame
      • Aug 2019
      • chile
      https://www.badcaps.net/forum/troubl...93#post3550093
      • mrgame
        • Aug 2019
        • chile
        K6N0CX028947233
        • hoaca388
          Badcaps
          • Jan 2022
          • 12403
          K6N0CX028947233
          Vivobook S14 S430
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
