Samsung Galaxy Book NP750XDA BIOS request
  • sect-sin
    • May 2022
    • 103
    • Hungary
    I have a Samsung Galaxy Book NP750XDA (board number NB3586/NB3587_PCB_MB_V5 REV:1.0. TITAN_MB). No charging light, no power, no POST. It had a burnt capacitor on the 3,3V line. After removing it, checking all rails and CS resistors for shorts, I powered it up. Charging light works, the battery is being charged. Powerup works, there is fan spin, but there is a constant power cycle and no POST. Furthermore, I get six long blue error blinks, but I have not found any info on what that means.
    All rails have the correct voltages. It might be a BIOS issue. I have attached the dump, could somebody fix it for me with the correct DMI info transferred?
    I thank you very much in advance.
    Cheers,
    sect-sin
  • sect-sin
    • May 2022
    • 103
    • Hungary
    Re: Samsung Galaxy Book NP750XDA BIOS request
    Hi, I am cautiously bumping this thread. Can somebody help me?
      • 22279
      Try this bios,don`t know if it will work or not
      • sect-sin
        • May 2022
        • 103
        • Hungary
        Hi SMDFlea,
        Thank you very much for picking this one up. I have to be honest (though i feel quite ashamed): I managed to physically LOOSE the BIOS chip. It was in the programmer, but the programmer fell on the floor as my kids decided to scramble around in my workshop without my presence. Now the chip is gone to another dimension. I must procure a replacement, and will give feedback after that.
        Cheers,
        sect-sin
        • xamledyD
          • Nov 2015
          • 8
          • Poland
          Hi
          I've got identical motherboard too. If you could not find original BIOS chip, you can use Macronix MX77L12850F and - if it's a BIOS related issue - it should work properly.
          I'll try to read my chip and post working BIOS in this thread.
          • sect-sin
            • May 2022
            • 103
            • Hungary
            This is unbelievably useful information, as I was having a very hard time finding the W25R128JVSO chip originally on my board. Though it seems the Macronix you mentioned is also out of stock everywhere. Nevertheless, I will bee looking out, thank you very very much!
            Cheers,
            sect-sin
            • xamledyD
              • Nov 2015
              • 8
              • Poland
              Probably GigaDevice GD25R128E is compatible with this board too.
              Have you read your BIOS chip with TL866 II Plus programmer? Your programmer detected BIOS chip as W25Q128JV (or you have selected it manually). From what I see, the difference between W25Q128JV and W25R128JV is that "R" labeled chip supports Intel RPMC (Replay-Protected Monotonic Counter). So when we are searching for replacement BIOS chip (apart from size, package and operating voltages), first we have to check if BIOS IC supports RPMC. There is also possibility that chips without RPMC will work with this motherboard but I haven't checked that.
              If it will be difficult to find a new BIOS chip, it may be easier to find a scrap board with this chip on internet auctions.
              • sect-sin
                • May 2022
                • 103
                • Hungary
                Yes, I use TL866+. I usually check automatic chip identification presented by XGecu, an I do not think that I have misidentified it, though it is not impossible. I searched for the GigaDevice you mentioned, it is also not available anywhere.
                The W25R128JVSIQ is in stock at Mouser. Do you think that it might be compatible? It also has RPMC, and the voltages are OK.
                I would never have thought that it is this difficult to get certain BIOS chips. I am forced too look out for a donor board, as you recommended. Thank you nevertheless for trying to help me.
                Cheers,
                sect-sin
                • xamledyD
                  • Nov 2015
                  • 8
                  • Poland
                  W25R128JVSIQ will be OK.
                  • xamledyD
                    • Nov 2015
                    • 8
                    • Poland
                    Working BIOS file from laptop with bent motherboard in attachment.
                    • sect-sin
                      • May 2022
                      • 103
                      • Hungary
                      Very cool, thank you very much. I have ordered the chip and will revert once it arrives.
                      Cheers,
                      sect-sin
                      • ANTODG93
                        • Apr 2023
                        • ITALIA
                        Hello everyone, I'm trying to reprogram the MX77L12850F bios with the CH341 PRO programmer but the ic doesn't respond, can anyone tell me if the programmer I'm using is suitable for writing this chip or is the chip simply broken?
                        Thank you all
                        • peste
                          • 13924
                          • ROMANIA
                          Thank you all
                          use one of these programs..
                          https://www.badcaps.net/forum/showpo...6&postcount=10
                          https://www.badcaps.net/forum/showpo...04&postcount=7
                          see also a video for example,,
                          https://www.youtube.com/watch?v=DWWigscuQDY
                          • ANTODG93
                            • Apr 2023
                            • ITALIA
                            Hi, at the moment I don't have the prepaid card with me but as soon as possible I will be happy to make a donation, the ic MX77L12850F is not even in the list of the two programs you sent me, if I press verify ic the program tells me that it is present, so I tried to write by setting ic MX25L12873F do you think it is the same?
                            • peste
                              • 13924
                              • ROMANIA
                              you can set any equivalent chip...
                              • ANTODG93
                                • Apr 2023
                                • ITALIA
                                Hello everyone, I tried to program MX77L12850F and the programming is successful, but unfortunately the pc shows no signs of life, do you have any other advice you can give me?
                                • peste
                                  • 13924
                                  • ROMANIA
                                  there are many variables here....did you write the right bios? did you write the correct bios? are you sure the bios is corrupted? what voltages do you have on the coils??
                                  • ANTODG93
                                    • Apr 2023
                                    • ITALIA
                                    I did programming with files from this community which are mentioned above are they correct for MX77L12850F ?
                                    I also checked the voltages on the bios pins and there is a voltage of 3.3v which is not stable but it fluctuates 3.3v/0v
                                    • peste
                                      • 13924
                                      • ROMANIA
                                      I don't think the problem is the bios... solve the problem of the unstable voltage of 3.3v
                                      • greewolf
                                        • Apr 2018
                                        • 9
                                        • Ukraine
                                        Good day ! please share eeprom dump ft24c256 for TPS65994 . There is 20 volts, but the keys do not open
                                          09-07-2024, 05:50 AM
                                          Samsung Galaxy Book NP750XDA Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book NP750XDA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP750XDA boardview and NP750XDA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-07-2024, 05:20 AM
                                          Samsung Galaxy Book NP750XDA-KC1IT Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book NP750XDA-KC1IT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP750XDA-KC1IT boardview and NP750XDA-KC1IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          Samsung Galaxy Book NP750XDA-KDAUK Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book NP750XDA-KDAUK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP750XDA-KDAUK boardview and NP750XDA-KDAUK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:10 AM
