BIOS Dell Precision 5570
  • foulou0238
    • Mar 2014
    • 109
    • France
    hello,
    i have here a new bios for 5570 withouth ST and need to do clean me or the CSME 16+ to do clean me .
    any help i will appréciate
    regards
  • aldopc
    • Jul 2017
    • 464
    • Chilito
    Re: BIOS Dell Precision 5570
    Originally posted by foulou0238
    hello,
    regards
    which problem you have? do not have the original bin of your dell?
    • foulou0238
      • Mar 2014
      • 109
      • France
      hello
      thank you for replay
      Of cours i have original dump but wrong ST .
      whene i change service tag with Hexedit i got fan spinning dell logo first time but nothing after .
      so i dumped a new bios file from a new mobo and flash the bios but get same error .
      when i put bios with wrong ST so computer work correctly with no issue .
      regards
      • aldopc
        • Jul 2017
        • 464
        • Chilito
        hello
        regards
        Ok, upload your original file and the correct service tag.
        • foulou0238
          • Mar 2014
          • 109
          • France
          hello
          here original dump
          Dump Tag JBC92T3
          Tag Needed 247W1T3
          i have to informe you that i change it in dump 3 times But didn't work
          i got DELL logo first start after fan speen ....
          thank you
          regards
          • aldopc
            • Jul 2017
            • 464
            • Chilito
            hello
            here original dump
            Dump Tag JBC92T3
            Tag Needed 247W1T3
            thank you
            regards
            Sorry I didn't realize this file is very different from the ones I've cleaned the st someone in the forum maybe can help
            • volinakis
              • Jan 2021
              • 2652
              • N/A
              hello
              here original dump
              Dump Tag JBC92T3
              Tag Needed 247W1T3
              thank you
              regards
              try this, it should enter in factory mode, 1st boot press F2 and write Service Tag, disable Absolute, save, restart, then press Alt+F to exit factory mode.
              • rtdias
                • Oct 2023
                • 9
                • Portugal
                Hello, this is my first post on the forum.
                I've read, in the last few hours, hundreds of threads on this forum. I must say I am completely overwhelmed by the knowledge sharing and spirit of comradery I've seen - Thank you fellows.
                I have a brand new Dell Precision 5570 that has been bricked by Absolute Computrace.
                I would like to ask if the method aboce would be sufficient to eliminate the issue (in other words, to allow me to disable Computrace at BIOS level)?
                many thanks in advance,
                rtdias
                • rtdias
                  • Oct 2023
                  • 9
                  • Portugal
                  By the way, laptop has Service Tag 9WCP4W3.
                  I have a second Precision 5570 that is currently working fine and from where I can extract a BIOS if required.
                  Any help would be VERY appreciated and would mean an instant donation to this forum.
                  (although I will donate in any case)
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11265
                    • Viet Nam
                    rtdias
                    Backup bios file and sevice tag ?
                    • rtdias
                      • Oct 2023
                      • 9
                      • Portugal
                      Hello, thanks for your support!
                      In attachment are the extracted BIN files from the Dell latest BIOS exe file.
                      I suspect not all would be needed?
                      The ST is 9WCP4W3
                      (I have assumed that the normal BIOS package from Dell would be sufficient, not an actual dump from my laptop, correct? I don't mind losing BIOS data, that's easy to configure as long as Computrace is gone)
                      thanks in advance for your support.
                      • volinakis
                        • Jan 2021
                        • 2652
                        • N/A
                        The ST is 9WCP4W3
                        nope, we need bios dump from your laptop in order to help you.
                        • rtdias
                          • Oct 2023
                          • 9
                          • Portugal
                          Yes. I understand. Unfortunately, booting the machine, even if in a rescue linux or PE environment, is proving extremely difficult, as Computrace has already actively taken over.
                          Is there any boot media that anyone would advise for a situation like this?
                          (preferably with BIOS dumping tools already pre-loaded)
                          I've tried Knoppix, Macrium and a couple others but they're not working well, not even booting sometimes.
                          Whenever the boot media is made writable Computrace kicks in a few minutes after booting.
                          This thing is a nightmare.
                          Thanks in advance for your support.
                          • rex98
                            • Feb 2023
                            • 1240
                            • Mandaue CEBU, Philippines
                            use the unlocked ones if you have absolute or bios pass. it unlocks just put the service tag in first boot.
                            if you have no display etc use the other one.
                            • rtdias
                              • Oct 2023
                              • 9
                              • Portugal
                              Thank you @rex98, a couple of "ignorant" questions:
                              1. How do I get the laptop to update the BIOS with a BIN file (rather than EXE)?
                              Is there a specific process?
                              2. Will it ask me for the service tag on the 1st boot or do I have to interrupt the normal process?
                              sorry, but this is not evident to me at the moment.
                                • 20364
                                The only way is flash the bios using an SPI programmer.
                                • rtdias
                                  • Oct 2023
                                  • 9
                                  • Portugal
                                  I was afraid that that would be the answer.
                                  How do I know which SPI Programmer is the best suited for my laptop/motherboard?
                                  Any advice?
                                  thanks in advance.
                                  • rtdias
                                    • Oct 2023
                                    • 9
                                    • Portugal
                                    However... if Dell is able to produce a an .EXE file and get it to flash the BIOS, why can't we?
                                    There must be a method to rebuild a BIOS .EXE file and skip the SPI programmer altogether?
                                    Please educate me! :-)
                                    • volinakis
                                      • Jan 2021
                                      • 2652
                                      • N/A
                                      because bios updates don't overwrite security settings, it will ask for password. And you don't know the password ... Try using DCPP to convince yourself. Read BIOS guides, methods, resources and tools made by master piernov to have a clue what is about.
                                      https://www.badcaps.net/forum/showth...t=phoenix+bios
                                      • rtdias
                                        • Oct 2023
                                        • 9
                                        • Portugal
                                        Thank you @Volinakis for your brief explanation. Yes, I read the BIOS guides and I am reasonably familiar with the topic.
                                        What password are you referring to? A secret manufacturer password on every machine or my own BIOS password?
                                        (in my case there's no password whatsoever, my problem is Computrace)
                                        When you mention DCPP, are you referring to "Dell Command Powershell Provider"?
                                        Sorry for all the questions. Thanks in advance for your replies.
                                        • trix11
                                          Dell Precision T1650 MT Workstation bricked after BIOS update
                                          by trix11
                                          I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                          - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                          - Dell Precision T1650 mid tower Workstation
                                          - Xeon E3-1225 V2
                                          - 32Gb PC3-12800E RAM
                                          - 4Tb SATA HDD
                                          - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                          I see now that others have experienced like issues e.g.:
                                          - https://www.dell.com/community/Prec...
                                          10-24-2022, 10:35 PM
                                          DELL Precision 5570 Mobile workstation 5000 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 5570 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                          09-07-2024, 06:40 AM
                                          09-07-2024, 06:38 AM
