Dell XPS 13 9365 - LA-D781P bios
  • newdes
    • Aug 2018
    • 34
    • MX
    #41
    Re: Dell XPS 13 9365 - LA-D781P bios
    Originally posted by Markus1741
    Try ...
    Thank You
    • zcinciev
      • Apr 2015
      • 3
      • Macedonia
      #42
      Hi.
      I'm not sure if I should make a new post, but let me know.
      I have the same model with no picture issue and I suspect the Bios is corrupted. When powered on with its bios it takes around 0.4amps then fluctuates and goes down to 0.227. With a few other bios files that I reprogrammed the power light goes on, but no power draw.
      Please advise,
      • javed964
        • Mar 2020
        • 23
        • Saudi Arabia
        #43
        Please can some one help me to clean this bios
        Model: XPS 13 9365 2-in-1
        Service Tag: 5VGX6H2
        • CornholioGSM
          • Feb 2014
          • 265
          • CZECH
          #44
          please fix/clean my bios. Machine powers on only for 1-3 seconds.
          Dell XPS 9365 / LA-D781P
          ST : 3Z0H1G2
          Thank you
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            #45
            ST : 3Z0H1G2
            Thank you
            try a new one
            • CornholioGSM
              • Feb 2014
              • 265
              • CZECH
              #46
              Originally posted by qayyum786
              try a new one
              thank you, but not good
              After pressing pwr button keyboard light goes on for one second and then again off
              Charging works without problem.
              • qayyum786
                • Aug 2018
                • 1959
                • INDIA
                #47
                try
                • CornholioGSM
                  • Feb 2014
                  • 265
                  • CZECH
                  #48
                  try
                  i will test it tomorrow
                  ...but it looks like hw problem
                  • CornholioGSM
                    • Feb 2014
                    • 265
                    • CZECH
                    #49
                    try
                    soo problem still
                    tested both files from you
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #50
                      soo problem still
                      Now its a time to start probing​
                      • kinoxa
                        • Dec 2011
                        • 26
                        • Kyiv
                        #51
                        Dell XPS 13 9365 - LA-D781P bios BAD
                        • qayyum786
                          • Aug 2018
                          • 1959
                          • INDIA
                          #52
                          ❤️YOU MUST:
                          ❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
                          ❤️Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms❤️
                          • kinoxa
                            • Dec 2011
                            • 26
                            • Kyiv
                            #53
                            service tag no
                            The laptop does not turn on when you press the "D" button to pass the matrix test.​
                            • qayyum786
                              • Aug 2018
                              • 1959
                              • INDIA
                              #54
                              service tag no
                              try
                              • kinoxa
                                • Dec 2011
                                • 26
                                • Kyiv
                                #55
                                Dell XPS 9365/LA-D781P
                                service tag 43VZ2M2
                                The laptop turns on for one second. When pressing the "D" button to pass the matrix test.​
                                • boris1212
                                  • Oct 2020
                                  • 18
                                  • israel
                                  #56
                                  Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is D2D81N2 . Here it the original dump
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12362
                                    #57
                                    XPS 13 9365 2-in-1
                                    Service Tag: D2D81N2
                                    • boris1212
                                      • Oct 2020
                                      • 18
                                      • israel
                                      #58
                                      Thanks for the help. Now I can go into the BIOS 3-5 times. It’s not my TAG that is detected
                                      • DAHOUD
                                        • Sep 2023
                                        • 35
                                        • Tanzania
                                        #59
                                        Hi guys i have Dell XPS 13 9365 - LA-D781P help me clean me
                                        when i switch turn off after few second i tried other file posted laptop display well but says ssd not installed
                                        sorry for not posting SERVICE TAG or SERIAL NUMBER has erased i dont see it
                                        • Italyfan
                                          • Jun 2018
                                          • 29
                                          • viet nam
                                          #60
                                          Hi. Please help me clean Me, the laptop keyboard lights up 2-3 seconds then turn off, no display. Thank you
                                          Dell XPS 9365 2 in 1
                                          Motherboard code: BAZ80/CAZ80 LA-D781P Rev 1.0 (A00)
                                          Service tag: 4QNV5H2
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
