Bios Acer E5-575 DAZAAMB16E0
  • xplodpg
    • Oct 2016
    • 30
    • Polska
    Hi. I needs bios. Forum bios don't work well. The laptop turns on but there is an error in device manager. The touchpad does not work.
    I'm sending my dump.
  • J_PH
    • Dec 2022
    • 37
    • Chile
    Re: Bios Acer E5-575 DAZAAMB16E0
    Hello,is it your original dump? check this.
    • xplodpg
      • Oct 2016
      • 30
      • Polska
      Yes it's original dump but is damaged. Only black screen. Maybe someone can fix the old bios
      • J_PH
        • Dec 2022
        • 37
        • Chile
        Check
        • xplodpg
          • Oct 2016
          • 30
          • Polska
          Originally posted by J_PH
          Check
          Laptop turn on but touchpad still not work
            • 20888
            Is it working with linux ?
            • xplodpg
              • Oct 2016
              • 30
              • Polska
              It doesn't work on Linux .
              • xplodpg
                • Oct 2016
                • 30
                • Polska
                I fixed the bios. Need to transfer serial numbers and model to your file.
                • peste
                  • Dec 2016
                  • 12792
                  • ROMANIA
                  let's understand that after you wrote the DMI information in the bios, the touchpad started working?? in which bios??
                  • xplodpg
                    • Oct 2016
                    • 30
                    • Polska
                    Yes. Bios from post #4. Bios does not have DMI data. After completing the data, the touchpad started working and device manager code 10 disappeared
                    • James194zt
                      Acer Nitro 50-640E Corrupted BIOS Dump
                      by James194zt
                      My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                      All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                      04-28-2025, 03:29 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • ZOrd_Z
                      Acer Predator P03-650 bios DUMP.
                      by ZOrd_Z
                      I need a bios dump to a Acer Predator P03-650 board.
                      Or to convert the .CAP file o a file to flash.
                      Thank's......
                      10-29-2024, 12:06 PM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      Today, 05:12 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
