Problem with BIOS password for MSI GT73EVR
  • adamantinus
    • Jan 2023
    • 6
    • Spain
    I have a problem with my BIOS password on MSI GT73EVR Laptop (2017)
    I forgot the password because I set it 3 years ago.
    Probably the pass is an easy example, but I don't remember. passwords that I try:
    B10s-p4ss
    H3ll0-W0rld
    B10s-Ms1
    gt73-t1t4n
    etc...
    I tried this:
    I opened the laptop and removed cmos battery, but password is persistent.
    Then i used the CH341A programmer to extract the BIOS to find the key with UEFITool. (attached .bin in txt)
    Here the hex code:
    20 16 9D F6 72 33 EA 38 15 84 E1 5D B5 73 EB 74
    6B B7 82 9E 00 00 00 00 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 C6 90 59 A0 A3 4A FE 37
    B7 D6 CF 88 9B 13 D9 7E B4 CE B4 24 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    01 00
    I have read this documentation.
    https://www.badcaps.net/forum/showthread.php?t=103526
    I try example for ASUS, HP and DELL this guide (but XOR calculator not work for this MSI)
    https://www.badcaps.net/forum/showpo...55&postcount=2
    I am doing something wrong?
    and this post:
    AMITSESetup Decryptor (I don't know Python, I don't understand why the script gives me an error)
    https://www.badcaps.net/forum/showthread.php?p=1098223
    (I did not succeed)
    I can't find exactly info for MSI and any solution shown there not work for me.
    I ask for help, if someone can help me to solve the password.
    (Sorry for my bad English)
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    Re: Problem with BIOS password for MSI GT73EVR
    It's better to upload your backup bios here, and someone will try to decrypt it or remove it for you.
    all donations are welcome,
    • adamantinus
      • Jan 2023
      • 6
      • Spain
      sharing my bios is not dangerous?
      I mean posting the BIOS includes my hardware info or serial number
      But I'm not sure,
      If I can solve it with XOR calculator, I prefer it
      Also, if others fix it for me, then there will be no documentation of this problem.
      • fxreen
        Banned
        • Sep 2022
        • 39
        • Brazil
        But I'm not sure,
        @adamantinus
        Your password uses an unknown hash, it is not possible to compute it with the standard AMI_key = int("0x935b", 16)
        • adamantinus
          • Jan 2023
          • 6
          • Spain
          Originally posted by fxreen
          @adamantinus
          ok, good,thanks for the reply.
          Is there a way to find out?
          with brute-force tool or hidden in nvram? for example.
          • adamantinus
            • Jan 2023
            • 6
            • Spain
            I didn't find any information, you're right.
            I am attaching the bios in case someone can help me remove the password or cancel it, i'm sorry for the delay.
            it's my first day here
            • hardware1
              • Sep 2021
              • 2930
              • N/A
              No Problem.
              Here's your Unlocked file, try it.
              • AAAC
                • Jan 2020
                • 458
                • Mexico
                @adamantinus
                Maybe it's a SHA-1 hash, 160-bit (20-hex bytes).
                • adamantinus
                  • Jan 2023
                  • 6
                  • Spain
                  No Problem.
                  The file worked, thank you very much
                  so the solution was to write zeros to the hash on both nvrams.
                  not erase, just fill...
                  That's why I had a checksum error
                  now everything is solved!!
                  • traxformania
                    TONGFANG "GM7TG7P" Bios Password Problem?
                    by traxformania
                    I tried :
                    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                    11-15-2023, 07:32 AM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • AquaMan Ua
                    by AquaMan Ua
                    05-17-2025, 09:40 AM
                  • outsider
                    Panasonic FZ-G1 MK5 - BIOS password returning
                    by outsider
                    Hello
                    I removed the BIOS password thanks to the help of one of the friends of this forum.
                    https://www.badcaps.net/forum/troubl...61#post3637661
                    The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                    06-17-2025, 12:51 AM
                  • RMDUiFT
                    Should I buy a Lenovo Thinkpad E495 with bios password?
                    by RMDUiFT
                    Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                    I have a few questions:
                    • If I would buy this laptop and have
                    08-25-2024, 09:00 AM
