Acer bios chip location
  • kamot37
    • Sep 2016
    • 39
    • Philippines
    Hi Guys i Need your Help again i have a Board with no display here I'm planning to backup/ flash the bios Chips but i cant locate the chips because its new for me..
    i attach the board model and the whole pic of board thanks a lot in advance Help!
    Board: FH50P LA-H901P
    Rev: 1A
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Acer bios chip location
    Try this
    • volinakis
      • Jan 2021
      • 2877
      • N/A
      Rev: 1A
      UC7, is a 1.8V chipset
      • kamot37
        • Sep 2016
        • 39
        • Philippines
        thanks a lot you guys for a quick reply
        • kamot37
          • Sep 2016
          • 39
          • Philippines
          thanks a lot guys for a quick reply guys one more thing i notice that the first mosfet (PQ310 is already jumper, and im planning to change it with replacement mosfet can anyone provide me some replacement, thank you..
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • inck243
            Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
            by inck243
            Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
            The BIOS...
            07-25-2024, 09:17 AM
