Asus ROG G513QR Amd
post S/N, full name and model, motherboard model, etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
M1NRKD02089102D I really need the BIOS please help me. Asus Rog Strix G513qr-hf010 g533-6050a3250201-mb-a02(a2) AMD Ryzen 7 5800H (8 (16) . nVidia GeForce RTX 3070, 8 GB GDDR6, 256-bit
Display 15.6" (1920x1080) IPS, 300 Hz
Bios was lost. please help meComment
Post a picture of the QR code near the CPU, like the one at post 9 ,or scan it yourself and post what it saysComment
G513QRAttached Files↵
https://www.badcaps.net/donateComment
please
With my BIOS No initialization
is my bios corrupted???Attached FilesComment
# 28Originally posted by SAnyoknokWith my BIOS No initialization↵
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
