Bios of ROG G752VL
  • alastres
    • Dec 2022
    • Cuba
    Bios of ROG G752VL
    If someone have in his power the .bin Bios of the Laptop Asus ROG G752VL, I need urgent this file for my laptop.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12392
    Re: Bios of ROG G752VL
    post your corrupt bios.
    • alastres
      • Dec 2022
      • Cuba
      I don`t have it on hand, in a few days I may be able to do so, can you please be patient enough until that?
      • shayanblack
        • Mar 2018
        • 16
        • sri lanka
        help to fix this bin...
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          What needs to be "fixed", explain in detail what the problem is with your machine?!
          P.S. The names of the cities and countries are written in capital letters. The same applies when starting a new sentence.
          Examples:
          Dankotuwa
          Sri Lanka (formerly Ceylon)
          Become a Badcaps supporter
          Thanks to all supporters.
          • cvtech
            • Mar 2014
            • 63
            • ph
            can someone help me i got G752VL with password
            can someone removed pass word thanks
            ASUS G752V
            dont know what is the serial number
            thanks
            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
            • hoaca388
              Badcaps
              • Jan 2022
              • 12392
              ASUS G752V
              thanks
              Serial number is found on the bottom cover of the device.
              Password : 13tylergw13
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • maanee11
                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                by maanee11
                Hello Everyone,
                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                In the website, you can only see specs etc.
                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                11-08-2025, 04:08 AM
              • m1ch43lzm
                by m1ch43lzm
                Hi everyone
                09-06-2025, 05:47 PM
              • Forest79
                by Forest79
                07-23-2023, 07:39 AM
