New Mina T2 activiation
This topic is closed.
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    hello guys,
    I was just informed Mina has released an update for new ibridge Os for t2 intel macs. have anyone tried if it's working and can old serial numbers be used?
  • imranromi
    • Jan 2015
    • 1297
    • Pakistan
    Re: New Mina T2 activiation
    Originally posted by bluestone
    hello guys,
    i think yes can use but update first new ibridge after activate as he share instruction.
    • .::iRizwan::.
      Banned
      • Apr 2016
      • 63
      • Pakistan
      • Too Much
      No you can't use old SN it's a new service, You have to register again even if you already registered it for old solution
      • imranromi
        • Jan 2015
        • 1297
        • Pakistan
        Correct today i bypass 2 Macbook its work good for solution is different trick.
        • kevingill
          • Jun 2013
          • 152
          • England
          T2RActivator - Macbook
          Has anyone tried the new mina T2RActivator with the old known serial numbers?
          The new version claims to work with newer bridgeos versions.
          Noticed the old thread has closed...
          • lc24cxx
            • Oct 2018
            • 13
            • 20100
            Re: T2RActivator - Macbook
            Seems iPU MACBOOK T2 ACTIVATOR is doing it too..
            Did someone have some luck to retrive user info from a T2 MacBook editing the file "FMMAccount.plist.plist" as iRizwan explain in the last post ? scp or commands list to retrive files from a jailbreak t2 device and path where is stored?
            • .::iRizwan::.
              Banned
              • Apr 2016
              • 63
              • Pakistan
              • Too Much
              Yes the new version works with Latest BridgeOS.
              As i said above you can't use Old Serial to this one, even you can't use same New Registered Serial to any other MacBook.
              They got aware of the trick people used in the past so bye bye cloning SN.
              • .::iRizwan::.
                Banned
                • Apr 2016
                • 63
                • Pakistan
                • Too Much
                IPU and others like this can just extract user info etc. from not erased Macbook nothing else.
                • Abdel13
                  NAPSTER
                  • May 2021
                  • France
                  Are you sure about that ? i mean you tired to activate other mac and it didnt works ?
                  thanks in advance
                  N A P S T E R
                  • anhbanxoi
                    • Sep 2021
                    • 181
                    • VN
                    thanks in advance
                    imranromi in post #4 he said that he can bypass 2 macbooks with some tricks.
                    • Abdel13
                      NAPSTER
                      • May 2021
                      • France
                      can you explain please ?
                      N A P S T E R
                        • 24616
                        This thread is closed. Youtube links to channels with paid unlocking services are against the site rules.Advertising or self promotion of any paid unlocking will also not be tolerated.
                        • 1centchips
                          a2159 not able to revive, disconnects at step 4 of reviving
                          by 1centchips
                          Goes to recovery when plugged in with another Mac, shows in finder with a question mark and serial number. When revived fails at error 9 (the laptop turns off and on?) In the Apple Configurator when in dfu, gives error restores device removed before restore completed 0xFAA (4010). Tried in intel and m1 based Macs.
                          History, came in with severe liquid damage and bubbly motherboard Transplanted t2/ recalled ram, u4730, all 4 nands and u4770.
                          Below is the log from console, the usb meter negotiates at 19v and goes as high as 2.4A
                          Apr 1 08:36:25 macs-MBP UARPUpdaterServiceDisplay[1440]:...
                          04-01-2026, 11:38 AM
                        • bouch
                          unlock macbook air A1932 2019
                          by bouch
                          hi
                          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                          I need help or information?
                          Does anyone have the minat2 activator 1.4 software?
                          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                          Thank yo...
                          03-12-2025, 10:14 AM
                        • bouch
                          activation a1932 2019
                          by bouch
                          hi i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 ,but fault ssh?
                          can you let me mina T2 activator 1,4 , i search it .
                          or have you other programme or method compatible whit this macbook ibridge 9,3 ?
                          have you solution for by pass ? thanks...
                          03-08-2025, 09:26 AM
                        • tobeend
                          Bypass iCloud MACBOOK t2 iBridge older 7.0
                          by tobeend
                          Does anyone know any solution to bypass the older iBridge?
                          because everyone now offers bypass only 7.2 and 7.4 as they are not so stable and I don't want to update from 5.5 to 7.5
                          Please suggest a way out of the situation
                          05-26-2023, 07:32 AM
                        • nelusab
                          by nelusab
                          Hi Stephen,
                          I already tried with 2 other batteries. this one has 168 cycles. I could boot with the battery pluged in but with trackpad cable disconected. It booted slow, and the fans where running noisy, and that's how I found information about the battery.
                          I've performed a new DFU Restore, this time with last version of macos Sonoma on both macs, and with the last iBridge. The same result. Please tell me this, DFU Restore operation is reflashing the entire T2 ROM file?
                          I have some KP messages.
                          I forgot to mention the fan where running fast but nothing was heating...
                          12-19-2023, 01:10 PM
