A2179 with backlight, but no image
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey everyone,
    I have a Macbook Air 2020 here that boots, gives backlight on the screen, but no image whatsoever. Just a backlit black display. I couldn't locate the boardnumber, will add to the thread as soon as I find it. Should I be looking in the software, or hardware direction?
    Edit1: I also don't get display with an external adapter. Could be the adapter tho, it's one from AliExpress, but it had good ratings.
  • spidertnt
    • Jul 2016
    • 34
    Re: A2179 with backlight, but no image
    Typically this is a bad screen....try an old cracked screen if you have.
    if testing external try unplugging the internal screen before testing external. If they have encryption enabled i'm not sure external display will work until OS is loaded.
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      I only have an A1932 screen lying around, and I'm not certain it is compatible although it looks the same.
      The light on the external hub lights up, but no image is coming trough. It is possible that this is because it's not unlocked indeed. But I don't think disconnecting the internal screen will change this?
      • Jenzo
        • Jul 2019
        • 135
        • Belgium
        Turns out the A1932 screen is compatible, connected it and works fine. So it is a display issue indeed! Weird since I figured I have backlight and no visible cracks in the lcd it wouldn't be but here we are. Thanx for the advice!
        • ajgae
          HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
          by ajgae
          Hi everyone!
          First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
          03-06-2025, 09:53 AM
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • malekservis
          Philips 58PUS8536/12 Backlight ok, no image
          by malekservis
          the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
          Any information would be appreciated....
          08-07-2024, 07:48 AM
        • koriwi
          P14s Gen 2 AMD; no boot, no image, no backlight, no charge
          by koriwi
          Hi guys, I am new here, but I've tried my best to read up on the beginner guides and reading some other threads. So here the base information i can provide.
          -Lenovo P14s Gen 2 AMD
          -Ryzen 7 5850u
          -16GB soldered (32GB stick added, removed for debugging)
          -256GB SKHynix SSD (removed and swapped for debugging)
          -NM-D451 Motherboard (P/N: 5B21C82277)
          -S/N: PF-34N64A
          -Model: 21A0-000QGE
          History and symptoms:
          I had this Laptop for some time but stopped using it (installed Linux, worked perfectly) as I changed company and got a MacBook...
          03-08-2025, 05:22 PM
