A1297 820-2914 JED GMUX file needed
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Hey guys,
    Looks like i cant find nowhere free JED file for 820-2914 board.
    https://github.com/ayilm1/gMUXBypass these looks like dont work on 820-2914, has not clear view (like old school snow) when reprogrammed. Anybody can share working one? Because months before applied dosdude's method with his payable files, and that worked.
  • zpi
    • Feb 2018
    • 132
    • Lithuania
    Re: A1297 820-2914 JED GMUX file needed
    Ok, managed to find out correct way. Will write info here for future generation geeks
    You can use attached JED file to 820-2915.
    But if you want to use it on 820-2914, then you will get blue tint on screen in the end. To fix this, you have to change R9240 and R9242 with 0 Ohm Resistors.
    Just tested on 820-2914 and i can confirm that this is correct way to do gpu delete on 820-2914. Have a nice day
    • payam
      • Nov 2015
      • 79
      • iran
      i have this blue tint screen problem
      thanks for your help
      best regards
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • hizuka00
        Asus FA707RR EC file Needed HELP!!
        by hizuka00
        Hello.
        Can you help me extract EC from BIOS dump?
        Asus FA707RR
        DANJMMB1AB0 REV: B
        SN: N6NRCX05B572239
        I have to replace the corrupted KBC (IT5570VG-128 dxg) but i can't find this file anywhere....
        Yesterday, 10:00 AM
      • Milovanovic1992
        Acer Aspire A515-45G File needed
        by Milovanovic1992
        Hello.
        I'm checking my friends laptop, which turns on without picture. I would like to try it with good bios, or if somebody can check original file from the laptop, and fix it.
        Model is A515-45G-R2TK
        SN : NXA89EZ001222000577600
        SNID : 22200008776
        MB : DAZAURMB8D0 REV: D...
        08-21-2025, 02:48 PM
      • wakethesleep1111
        Bios File Needed for asus tuf15
        by wakethesleep1111
        Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
        05-27-2025, 10:56 PM
      • Daniel Larsson
        Firmware file for Marantz NR1501 needed
        by Daniel Larsson
        I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
        After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
        The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
        The content of these seems to be useless as far...
        05-23-2025, 04:11 AM
