acer aspire nitro an515-54 missing 3v
  • dqtech
    replied
    Re: acer aspire nitro an515-54 missing 3v
    Originally posted by mon2
    Yes, this part but the other meter lead should be on the other side of this coil. We want to know the resistance of this component.
    This is a shielded coil and the coil is based on many turns of wire inside the shield. Want to confirm that the coil is not damaged.
    this is okay right?
    both probe on this PL301 coil
  • mon2
    replied
  • dqtech
    replied
    No. Meter in resistance mode. No power to the logic board.
    One meter probe on one side of PL301. Other meter probe on other side of PL301.
    What is the resistance?
    this one sir...8kOhm
  • mon2
    replied
  • dqtech
    replied
    Wow. Quite the game.
    Remove all power. Meter in resistance mode. Check the resistance across the PL301 contacts.
    What is the measurement?
    do you mean check all resistance on this part?
  • mon2
    replied
  • mon2
    replied
    Good reading at 8k34 ohms. That is not a short. The regulator should be on. Will review the details of this regulator deeper after the soccer game. Fairly sure it is active high enable which you have.
    Post close up pics of this regulator and parts. Any burnt looking parts in this region?
  • dqtech
    replied
    The meter has 3 functions in the yellow setting.
    You are currently in DIODE mode. Press the yellow button till you see the greek symbol OMEGA for the resistance scale.
    Then take your measurement again.
    sorry my bad...this one?
  • mon2
    replied
  • dqtech
    replied
    in DC volts mode, no voltage reading at all on PL301
  • dqtech
    replied
    Can you double check this? Resistance checks will be with no power, meter in resistance mode.
    One meter probe on PL301, other meter probe to ground.
    Resistance will be in ohms. If you read '1' or 'OL', then the meter scale is too low. Select the next higher scale on the meter till you have a reading.
    After the above, meter in DC volts mode (10 volts or higher). Then check the voltage to ground of PL301.
    am i right?
    i only have this multimeter
  • mon2
    replied
    PL301 resistance read 0.348v
  • dqtech
    replied
    reading on all part that link with PL301 is normal...accept PR305 that should be 100k but only read 89k...is that okay?
  • dqtech
    replied
    Check the resistance of the parts and reflow these parts at the output stage of this regulator that link with PL301.
    Compare the resistance values against the schematic values.
    The LDO working is a good start. The switching regulator leg of the regulator should be on as well.
    With no power, measure the resistance to ground again of PL301. What is the reading?
    PL301 resistance read 0.348v sir
  • mon2
    replied
  • dqtech
    replied
    1) is the replacement part a known good part?
    2) same part number as the original?
    3) what is the voltage to ground of the LDO rail on this regulator?
    4) confirm the soldering with lots of flux, enough hot air and air pressure to make this part swim and naturally rest onto the pads. When the solder is in liquid state, gently push the IC at the corners and the IC will push away and return back onto the pads. This process will fix any potential solder shorts. Then allow it to cool and test again.
    5) if the parts on this regulator circuit are not missing, the voltage should be present if the solder blob is removed. That is, a no load should allow for the proper voltage output.
    1) yes, new ic
    2) yes same with original part
    3) LDO on pin 17 got 3.3v
    4) yes everything good
  • mon2
    replied
  • dqtech
    replied
    See attached.
    Post your voltage reading to ground after the short / solder blob is removed.
    no reading on +3VALWP (pin 1) sir
  • mon2
    replied
    See attached.
  • dqtech
    replied
    19V is reaching the IN pins on PU301 ?
    What is the resistance to ground of the LDO and 3VALWP ?
    If the readings are not low, then PU301 is defective and should be replaced.
    When shopping for a replacement (recommend Hong Ming on Aliexpress - they have been good for our past purchases) - be sure to share the full part #. Often the suffix of the part number will define the enable pin logic levels, etc.
    update....i already replace PU301 with new ic but also not work...3valwp not present
    ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
    This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-12-2024, 03:28 PM
    ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
    This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-12-2024, 02:30 PM
    ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
    This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
    09-06-2024, 05:27 AM
    ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
    This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
