Hello everyone! I am hoping someone can help me figure out what's going on with this machine. From what testing has been done I can see the motherboard looks like it is trying to power on(fans spin for a second, CPU and GPU start to warm up) but no picture ever displays and when in its case it seems like no signs of life(no keyboard or charging lights). At first I was thinking it could possibly be a bios related issue but now I'm not convinced. The system seems to be getting its 19v, 5v and 3v power. The other thing I noticed was one of the inductors in the vrm seems to heat up really fast when plugged in(R22 2117). I can swap components if it needs but I figured I'd ask the community first if it's even possible to salvage. I cannot locate a replacement inductor online or from any donor machines otherwise I would have swapped it just to see. I am still trying to learn electronic diagnostics and appreciate any help. Thanks!!!
Razer R709-0367BEC3
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
Channel: BIOS Requests ONLY!
by theplopRazer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
I've run memtest quite a few times, and more often then not...4 Photos -
by shellybellyBack Story
I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be... -
Looking for schematic for RAZER BLADE 15 RZ09-0369. Looks like the motherboard is Razer DA560. TIA-
Channel: Schematic Requests ONLY!
05-12-2024, 10:25 PM -
by sikocanHello Colleagues,
I'm dealing with a perplexing issue on a client's laptop and would appreciate your insights. The user experienced a sudden screen blackout during regular use (not gaming), although the laptop continued to operate normally otherwise, with music playing and indicator lights active. An external display connected via HDMI works fine, indicating the display itself is functional. The device manager shows the Intel XE GPU as disabled, with Windows reporting a related error, while the NVIDIA RTX GPU operates without issues, even supporting gaming.
Upon inspection,... - Loading...
