Dell E5530 completely dead and MOSFET getting HOT! Please help.
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    So I'm trying to fix the above mentioned dell laptop. It has no signs of life at all when plugged in. If I connect the AC I noticed the MOSFET PQ5 gets very hot. So I'm assuming there is a short somewhere. I'm still learning so please could someone assist me. Thanks for any help given.
    I did try swopping the Mosfet which is a AO4423 with one from a donor board being a SI4483ADY as they both have the same VDS @ 30V. once I swopped the Mosfet when I plugged in the charger it would just switch off so I swopped the MOSFET back.
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Re: Dell E5530 completely dead and MOSFET getting HOT! Please help.
    Measure the MOSFET between Drain and Source while it's unsoldered, is there a short on the meter in diode mode in both directions?
    Are you able to measure total power consumption of the whole board? I.E. by connecting it to a lab power supply.
    When MOSFET is desoldered, measure point +DC_IN_SS to ground in diode mode, is there a short? If There is, inject a small voltage, no more than 1,5V to start with and check what gets hot.
    • roxboy1984
      • Jan 2022
      • 177
      • South Africa
      Thankyou for your reply. I will do as you suggested and report back.
      I do have a lab power supply. Please excuse my ignorance but how do I measure total power consumption using it?
      With voltage injection. Where would I inject the voltage from exactly? Black probe on ground and red probe on what component. I know this is probably a very noob question but I've never done it before. Thanks again for the help.
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        With voltage injection. Where would I inject the voltage from exactly? Black probe on ground and red probe on what component. I know this is probably a very noob question but I’ve never done it before. Thanks again for the help.
        You can get a raw cable that is being used with Dell power bricks, connect that to lab power supply, set to 19.5V then connect to laptop and observe the drawn current on the power supply. If it maxes out and goes into constant current mode then it's a true short.
        As for voltage injection, Inject the + on the marked point where MOSFET resides, removing the MOSFET is not mandatory to do this unless it's shorted out. Remember no more than 1.5V to start with, we don't know if for example a part of supply of CPU or other low voltage part like PCH is not shorted and we don't want to damage the delicate part. If current draw is very low or you can't detect the heat from the shorted component, you can gradually increase the current on the lab power supply until you get to about 2A, you should be able to detect the heat then.
        • roxboy1984
          • Jan 2022
          • 177
          • South Africa
          Thanks for the info. so I did as you suggested and these are the results.
          I removed the Mosfet measured in Diode mode I get 0.187 from source to drain and vice versa.
          I tried injecting 1.5V but i couldnt feel anything getting hot. I will try increasing and test again.
          I didnt have a Dell Power brick to kill so i set power supply to 19.5V and put the red probe on the Positive where the DC jack is and the picture is the result.
          • mon2
            • Dec 2019
            • 14547
            Remove all power. Meter in resistance mode.
            What is the resistance to ground of the source pins on PQ5 ?
            Resistance to ground of the drain pins of PQ5 ?
            You are drawing 87 mA of current which is very low so the logic board is not being powered.
            • roxboy1984
              • Jan 2022
              • 177
              • South Africa
              Source to ground is 7.5 Kilo Ohms
              Drain to ground 7.68 Kilo Ohms
              • roxboy1984
                • Jan 2022
                • 177
                • South Africa
                I also removed PQ5 and injected 2Amps and nothing is getting hot. even borrowed a thermal cam and cant see anything getting hot.
                • FrozenHaxor
                  • Jun 2015
                  • 260
                  • Poland
                  What's the voltage going while you have 2A of current? If it's low like 0,5V then bump up the current. Most of the power probably gets lost in the leads.
                  • mon2
                    • Dec 2019
                    • 14547
                    The issue may also be that you are not able to properly emulate the PS_ID that is required for the Dell boxes. With your bench power supply, the PS_ID single wire communication to the logic board is missing.
                    • roxboy1984
                      • Jan 2022
                      • 177
                      • South Africa
                      The board is taking 1.09V and 2amp.
                      • roxboy1984
                        • Jan 2022
                        • 177
                        • South Africa
                        Does this mean that i need to find a dell Adapter and cut off the jack and connect it to my bench psu?
                        • roxboy1984
                          • Jan 2022
                          • 177
                          • South Africa
                          Ok so after i injected more current and checked with thermal cam i found a ceramic capacitor that was getting hot so i swopped that out and now when i inject voltage it went from accepting 1.5v and 2 amps to 1.5v and 0.003 amps. What does that mean? good or bad? Thanks
                          • mon2
                            • Dec 2019
                            • 14547
                            Very good. So you have found and removed a shorted cap.
                            This is with the mosfet removed (PQ5) ?
                            While PQ5 is removed from the logic board, confirm that it is not defective if you have not done it already.
                            Meter in resistance mode, no power, check:
                            source (1-2-3) & drain (5-6-7-8)
                            source (1-2-3) & gate (4)
                            gate (4) & drain (5-6-7-8)
                            Post the readings and scale used on your meter for the measurements.
                            If you have a low resistance reading then the mosfet may be defective. If the resistance values are ok -> solder it back onto the board. Once the power path is complete, the power consumption should be higher.
                            That is, this mosfet likely was heating up due to the shorted cap you have found. Good job!!
                            • roxboy1984
                              • Jan 2022
                              • 177
                              • South Africa
                              Thanks again for all the help. so i took a chance and connected things back up to test with the AC plugged in and i noticed the following under the thermal cam.
                              the following in the pics get hot.
                              • roxboy1984
                                • Jan 2022
                                • 177
                                • South Africa
                                Ok so i swopped out PQ5 which is a AO4423 MOSFET with a VDS of 30V with a MDS3604URH MOSFET which also has a VDS of 30V. Now PQ% no longer gets hot but PQ1301 & PQ1302 get very hot.
                                Do you think perhaps they are bad? i cant read whats written on them to try and find a substitute.
                                • mon2
                                  • Dec 2019
                                  • 14547
                                  Yes, perhaps damaged but they are acting like SPST switches to allow for the charger IC to measure the current being consumed by the main logic board power rail. The charger IC is measuring the voltage drop across the current sense resistor @ PR1301.
                                  Respectively, these mosfets should not be getting hot unless there is some excessive loading event.
                                  Remove all power -> meter in resistance mode.
                                  Measure the resistance across:
                                  source & drain
                                  source & gate
                                  gate & drain
                                  pins of each mosfet. Post their measurements.
                                  The part is a jellybean P-channel mosfet and can be replaced with many others.
                                  The following should work fine:
                                  https://www.digikey.com/en/products/...03TRPBF/812496
                                  • roxboy1984
                                    • Jan 2022
                                    • 177
                                    • South Africa
                                    source & drain
                                    source & gate
                                    gate & drain
                                    Ok so these are the measurements of those two mosfets.
                                    PQ1301
                                    source & drain = 106 ohms
                                    source & gate = 106 ohms
                                    gate & drain = 5.76 Kilo ohms
                                    PQ1302
                                    source & gate = 104 Kilo ohms
                                    gate & drain = 0.5 ohms
                                    • mon2
                                      • Dec 2019
                                      • 14547
                                      Both look too low in the readings.
                                      Carefully remove each and measure them when they are out of the circuit to confirm the readings are consistent. They appear to be defective based on the thermal view and the low resistance readings.
                                      • roxboy1984
                                        • Jan 2022
                                        • 177
                                        • South Africa
                                        Thanks i shall do that and post back a bit later. is there anything i need to take note of when swopping them out from a donor board if they are faulty? other than VDS?
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • wangbreeze
                                          T480s random shutoff and then completely dead
                                          by wangbreeze
                                          Hello Gurus,
                                          I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                          I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                          Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                          charger gave - 20V - ok
                                          U101B
                                          02-03-2024, 04:57 PM
                                        • pavski
                                          Completely dead MSI z490 tomahawk
                                          by pavski
                                          Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                          I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                          t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                          Can you please let me know if this is indeed incorrect and what else should I look at next?
                                          Thanks!
                                          06-02-2024, 02:42 PM
                                        • Andreasbest
                                          Lenovo Thinkpad T14s completely dead.
                                          by Andreasbest
                                          Hello.
                                          I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                                          I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                                          Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                                          Thank you in advance!
                                          Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                                          03-19-2024, 03:18 AM
