Dell E5530 completely dead and MOSFET getting HOT! Please help.
  • mon2
    • 14685
    Re: Dell E5530 completely dead and MOSFET getting HOT! Please help.
    P-channel; SOT23 package; 30V and approx current similar to original although this requirement is not critical since there is no load if working properly on these mosfets.
    Perhaps the heating is due to the other parts mating with this one so best to test again when each mosfet is removed from the logic board.
    • FrozenHaxor
      • Jun 2015
      • 266
      • Poland
      Current capability of replacement MOSFET must be equal or greater for reliable operation. Make sure Rdson is low as well (lower is better).
      • roxboy1984
        • Jan 2022
        • 177
        • South Africa
        Originally posted by mon2
        Both look too low in the readings.
        Carefully remove each and measure them when they are out of the circuit to confirm the readings are consistent. They appear to be defective based on the thermal view and the low resistance readings.
        Out of the circuit these are the readings im getting.
        PQ1301
        source & drain = 4.3 kilo ohms
        source & gate = 0.231 kilo ohms
        gate & drain = 4.24 Kilo ohms
        PQ1302
        source & drain = 0.205 Kilo ohms
        source & gate = 0.203 Kilo ohms
        gate & drain = 2.3 ohms
        • roxboy1984
          • Jan 2022
          • 177
          • South Africa
          Im battling to read any of the markings on the jellyfish mosfets on the donor boards i have as i dont have a scope. Ive managed to make out i think "WT11" and a "BK3" "K72" "702W" "34nx5" would any of these work as a replacement for PQ1301 and PQ1302?
          • mon2
            • 14685
            No. The donor parts are N-channel but we need P-channel mosfets.
            Do you have access to Digikey / Mouser / Arrow electronics in your region? AliExpress is an option but will take time.
            • roxboy1984
              • Jan 2022
              • 177
              • South Africa
              #26
              I have the following donor boards. surely they must have a p-channel i can use? ACLUA/ACLUB NM-A273, DAOLX6MB, dv15 brazos mb - 10302-1.
              the above options you listed will take forever where i live unfortunately.
              • roxboy1984
                • Jan 2022
                • 177
                • South Africa
                #27
                So I just wanted to ask a question. would it be a viable option to remove those mosfets and inject voltage bypassing those mosfets and see if something else gets hot to determine if it is indeed those mosfets that are the issue. if so, where would you recommend injecting voltage from?
                • roxboy1984
                  • Jan 2022
                  • 177
                  • South Africa
                  #28
                  If i inject voltage then PU11 "CD3301B"starts to heat up.
                  • roxboy1984
                    • Jan 2022
                    • 177
                    • South Africa
                    #29
                    ok so using a scope i am able to read the Mosfets that are heating up. They have the following written TR2N, If i look up this Mosfet online it is saying that its an N-channel ? Is this correct? https://alltransistors.com/mosfet/tr...ansistor=37216
                    • max-power
                      Dell E6540 laptop completely dead after dssasembly
                      by max-power
                      Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                      that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                      After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                      03-24-2025, 08:49 AM
                    • Jane
                      How do you test MOSFET in laptops ?
                      by Jane
                      I tried to use this method:
                      Testing an N-channel MOSFET:
                      Step 1: Discharge the Gate (turn off the MOSFET)
                      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                      Step 2: Charge the Gate (turn on the MOSFET)
                      Now, place the red probe on the Gate (G) and the black probe on the
                      09-27-2024, 03:31 AM
                    • wangbreeze
                      T480s random shutoff and then completely dead
                      by wangbreeze
                      Hello Gurus,
                      I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                      I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                      Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                      charger gave - 20V - ok
                      U101B
                      02-03-2024, 04:57 PM
                    • pavski
                      Completely dead MSI z490 tomahawk
                      by pavski
                      Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                      I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                      t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                      Can you please let me know if this is indeed incorrect and what else should I look at next?
                      Thanks!
                      06-02-2024, 02:42 PM
                    • Andreasbest
                      Lenovo Thinkpad T14s completely dead.
                      by Andreasbest
                      Hello.
                      I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                      I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                      Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                      Thank you in advance!
                      Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                      03-19-2024, 03:18 AM
