Dell P75F010 not power on, no short
  • digitalblade
    • Mar 2016
    • 27
    • italy
    I've a Dell P75F010, with a FDI40 LA-G716P motherboard that don't power on at all.
    I connected the MB to a bench power supply, 19v 1Amp and when I press the power button, nothing happen, no current drawn (some little fluctuation like 0.0005 to totally 0). So seem that I don't have any obvious short..
    I just checked the first two mosfet that are immediately after the power connector and the first one was blown (is an AON6994, the first one will have a little hole on surface..) I replace it and now both mosfet has 19v on source.
    I did some check around the board and i found 19v on some places (around the lcd connector, and so on) also i found the 5v on some components.
    There is some other check that I can do? is the boardview/schematic available?
    thank you for any support!!
  • mon2
    • 14662
    Re: Dell P75F010 not power on, no short
    Check the voltage to ground of each coil / inductor on the board.
    Each such coil is linked to a power rail. Is each power rail producing the proper voltage?
    What is the gate voltage of the DCin mosfets?
    Which charger IC is onboard?
    • ACS-Repair
      • Feb 2021
      • 204
      That Dell model requires an adapter with 3.34A (65w).
      Have you tried increasing the current on your power supply?
