LA-D993P No power no charging
  • tipoti
    • Oct 2015
    • 34
    • turkey
    hello
    When you press the power button, the light turns on and off. It was working normally until a day ago. +3VALW ,+5VALW and power_sw have 5 volts, won't charge and won't turn on
    P65F
    LA-D993P REV 1.0
  • mon2
    • Dec 2019
    • 13903
    Re: LA-D993P No power no charging
    After the lights turn OFF - do you still have the +3VALW ,+5VALW and power_sw voltages?
    Are you using the original and official power adapter ?
    • tipoti
      • Oct 2015
      • 34
      • turkey
      it was working with non original charger. The battery was not installed. When I arrived in the morning, I noticed that the device was not turning on. I tried with another original charger and it still didn't turn on.
      +3VALW ,+5VALW and power_sw 3 volts have
      • mon2
        • Dec 2019
        • 13903
        See attached.
        1) Start with the charger IC @ PU300.
        Attach a known good power adapter -> meter in DC volts scale (30v or higher).
        Carefully (!) measure the voltage of each of the highlighted IC pins.
        Interested in:
        Vcc (pin #28)
        REGN (pin # 24)
        ACDET (pin # 6)
        ACOK (pin # 5)
        ACDRV (pin # 4)
        Post each measurement.
        2) Next, remove all power / no battery.
        Meter in resistance mode -> check the resistance across the mosfet pins:
        PQ306 & PQ302
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each resistance measurement and the scale used on your meter for the checks. As per above sticky from @Pienov - often the 2nd mosfet gets damaged.
        reference:
        http://electronicsbeliever.com/how-t...-is-defective/
        * see the section on resistance checks
        • tipoti
          • Oct 2015
          • 34
          • turkey
          Vcc (pin #28) = 19.7 Voltage
          REGN (pin # 24) = 6 Voltage
          ACDET (pin # 6) ACOK ( = 2.7 Voltage
          pin # 5) = 3.3 Voltage
          ACDRV (pin # 4) = 25.8 Voltage
          PQ306 diod mode : 0.465 /
          source (1-2-3) & drain (5-6-7-8) = resistance mode :465 ohm
          source (1-2-3) & gate (4) = resistance mode :611ohm
          gate (4) & drain (5-6-7-8) = ---
          PQ302 diod mode : 0.513 /
          source (1-2-3) & drain (5-6-7-8) = resistance mode :513ohm
          source (1-2-3) & gate (4) = resistance mode :606 ohm
          • mon2
            • Dec 2019
            • 13903
            1) Charger IC voltages look good.
            2) The mosfet resistance readings are not ok if the readings are indeed in ohms.
            3) Remove all power and with flux and hot air, remove PQ302 off the board. Careful of the air pressure so that other tiny nearby parts do not go flying.
            Then wait for the removed mosfet to cool and check the resistance in the same way of the part that you have removed.
            Is the removed mosfet still with these very low readings?
            Also check the resistance values of the PQ306 mosfet (now that PQ302 is off the board and should not influence the measurements).
            • tipoti
              • Oct 2015
              • 34
              • turkey
              sorry
              I typed wrong kΩ
              https://we.tl/t-cfstD6JZ3t
              • mon2
                • Dec 2019
                • 13903
                Then the resistance appears to be ok for the mosfets.
                Before placing the mosfet back onto the board, check the resistance to ground of the removed mosfet pads:
                source (1-2-3)
                gate (4)
                drain (5-6-7-8)
                if the power is not remaining ON for the main power rail then you may have an excessive current draw which is being sensed -> could be a broken current sense circuit which will result in the same observation. Or the bios of the EC controller may need to be reflashed.
                • tipoti
                  • Oct 2015
                  • 34
                  • turkey
                  source (1-2-3) = 398 kΩ
                  gate (4) = 416 kΩ
                  drain (5-6-7-8) = 130kΩ
                  i tried the bios
                  • mon2
                    • Dec 2019
                    • 13903
                    Looks ok.
                    Check the resistance to ground of each coil (inductor).
                    • tipoti
                      • Oct 2015
                      • 34
                      • turkey
                      I checked the coils, there is no low resistance or short circuit.
                      When the device was in its last working state, the battery was not plugged in and the non-original charger was connected
                      The PS_ID line goes in MEC1404. Could the mec 1404 be faulty? Due to fake charger
                      • mon2
                        • Dec 2019
                        • 13903
                        What is voltage of PS_ID ?
                        • tipoti
                          • Oct 2015
                          • 34
                          • turkey
                          PS_ID =3.4 Voltage
                          • tipoti
                            • Oct 2015
                            • 34
                            • turkey
                            I haven't been able to fix the problem yet
                            There is a working motherboard. does it help fix the other
                            • mon2
                              • Dec 2019
                              • 13903
                              Yes, it can help.
                              Does the working unit use the same or different power adapter?
                              • Scoff
                                HP Probook 470 G4 - Power and Charging Problem
                                by Scoff
                                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                07-03-2023, 09:28 AM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • rob_hen
                                Dell XPS 13 9370 Laptop, No power, not charging
                                by rob_hen
                                Hello!
                                This is my first post for help, and I am quite newer to board repair, so bear with me.
                                I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
                                After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
                                There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
                                My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
                                05-01-2025, 09:20 PM
                                Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                                by sam_sam_sam
                                I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                                https://www.ebay.com/itm/116497313155?var=416785404161
                                Here are some of the description from the eBay seller
                                The main parameters:
                                1. Product name: High-power non-isolated DC boost module power supply.
                                2. Product model: 100A2000W.
                                3. Input voltage: DC12V-60V.
                                4. Input current: 100A (maximum)....
                                05-18-2025, 09:45 AM
