Spectre X360 DAX38CMBAG0 - overheating fans not spinning
  • magneh
    • Apr 2014
    • 602
    • Portugal
    Hello all
    Got this Spectre with an overheating problem.
    I verified that the fans start briefly during power up, but never turn on again,
    even when stress testing the machine and CPU at 100°C fans dont spin
    Ive measured and I have 5V, 3.3v and 3rd pin 0.
    When fans spin during start up, the signal at 0v is at 1.6v.
    Probably its Fan2Sig pin and 3.3V is PWM, not sure
    Question is , how to fix?
    I think these signals come from ITE controller am I right?
    Should I bother replacing it?
    Thanks for any advice
  • magneh
    • Apr 2014
    • 602
    • Portugal
    Re: Spectre X360 DAX38CMBAG0 - overheating fans not spinning
    note: measurements on the 4 pin header of the fan
    • mon2
      • Dec 2019
      • 14550
      I would inspect if the fan itself is ok and clean enough to spin freely. The fan may be gummed up and needs to be replaced.
      Yes, the PWM signal is likely the 3v3 but this may be due to the actual PWM being absent. The pull-up on that line is defaulting to 3v3 = max fan spin.
      Review this webpage which offers some details on the operation of a similar fan (see the schematic & explanation of the PWM signal):
      https://www.electroschematics.com/4-wire-pc-fan/
      Confirm:
      1) your fan is a 5 volt model - appears to be
      2) the feedback (tach) signal is what you are measuring @ 1v6 when the fan does spin
      3) with the PWM @ 3v3, it should be spinning all the time - can you try to manually spin the fan after power up? Does the fan continue to spin?
      • magneh
        • Apr 2014
        • 602
        • Portugal
        Well fans spin freely, as they spin lie for 3secs when machine turns on.
        And even more now that ive tested, they sometimes kick in when in windows.
        But they dont kick in as they should, as CPU is almost 100degrees and they still dont spin.
        But if I wait, they eventually kick in but cleary they dont act as they should.
        Ive updated bios to latest, still the same
        Any idea what could cause this?
        Pretty sad to have a nice machine like this, burning hot all the time.
        regarding the 4 pins, I see that when they spin the grey wire has 1.6v and the 3.3V pin comes down to 1.6v also
        When they stop, 3.3V present again and grey wire 0v
        • mon2
          • Dec 2019
          • 14550
          The fan will only spin if the upstream fan controller receives a condition to need for this fan to enable to cool the board. That is, the upstream controller is monitoring a thermal sensor which will have a threshold temperature configuration and then the fan is requested to turn ON or OFF.
          The thermal sensor should be located for an inspection. Often have seen simple transistors being used as a thermal sensor.
          Is there a schematic available for this logic board?
          • magneh
            • Apr 2014
            • 602
            • Portugal
            The closest I could find was this one, but board layout is quite different.
            I think I will struggle to locate that simple transistor without the schematic for this board in particular...
            [MOD EDIT] Link to Quanta X32 schematic - https://www.badcaps.net/forum/troubl...s-drawings-bom
            • mon2
              • Dec 2019
              • 14550
              Found a (paid) schematic that may be close and it shows that the fan is controlled by the IT8987 IC. Locate it. No experience in this arena so wait on others to comment. Perhaps this device needs its flash to be reprogrammed (if there is one).
              • magneh
                • Apr 2014
                • 602
                • Portugal
                Hello!
                yes, ive referred that on the first post. ITE IC is the one controlling the PWM of the fan.
                Thing is if hes getting the right inputs to actuate those signals...
                Hard to conclude without schematic...
                • mon2
                  • Dec 2019
                  • 14550
                  Post pictures of the full logic board so we can review the shape.
                  What are the exact markings of your ite chip?
                  Does the laptop raise a fan error code?
                  The temp sensor will likely be connected to the a/d lines for the analog to digital conversion.
                  Posting some schematic segments from another x360 model.
                  Q: Is your ITE chip the same? Likely is the same but confirm it.
                  Q: Is your ITE chip a TQFP package or a BGA package? If TQFP, follow the schematic with the pin numbers. If BGA, then you will have to review the alphanumeric indexing.
                  Your logic board design will be very similar or identical.
                  • magneh
                    • Apr 2014
                    • 602
                    • Portugal
                    Hello there!
                    The laptop does not raise a fan error. When I disconnect one, it detects it.
                    ITE chip is IT8987VG , BGA package
                    I can see the temps in windows of cpu and GPU
                    CPU goes close to 100C often
                    So I think temp sensor works fine
                    • mon2
                      • Dec 2019
                      • 14550
                      Interesting read:
                      https://h30434.www3.hp.com/t5/Notebo...F/td-p/7279755
                      • emil_t
                        RTX3090 working fine but fans not spinning
                        by emil_t
                        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                        04-12-2024, 06:54 AM
                        HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                        This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 12:10 PM
                        HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                        This specification for the HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 Conv13-aw0054na boardview and Spectre x360 Conv13-aw0054na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                        09-06-2024, 11:50 AM
                        HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                        This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 07:20 AM
                        HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                        This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 06:21 AM
