dell 5110
  • baki60
    • May 2020
    • 78
    • Türkiye
    dell 5110
    dell 5110 first time i did it but the screen is flickering where do i check master
    uma
    https://yuzbasioglu.net/5110.mp4
  • baki60
    • May 2020
    • 78
    • Türkiye
    Re: dell 5110
    help please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: dell 5110
      The video you linked is not clear or atlest i dont see any problem there. Describe in detial what's your problem. Do you mean lcd backlit is flickering??
      • baki60
        • May 2020
        • 78
        • Türkiye
        Re: dell 5110
        yes master lighting is flickering
        i tried another panel
        • mielta
          • Apr 2015
          • 368
          Re: dell 5110
          Hi
          It looks like Panel or LCD Cable
          • baki60
            • May 2020
            • 78
            • Türkiye
            Re: dell 5110
            i tried master
            • mon2
              • Dec 2019
              • 14505
              Re: dell 5110
              https://www.dell.com/community/Lapto...0/td-p/3898401
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Re: dell 5110
                Measure voltage on LVDS connector for pin 1/5/30
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • The WABBIT
                  Dell Inspiron 5559 need BIOS Master PW
                  by The WABBIT
                  I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
                  After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
                  Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
                  07-12-2021, 04:20 PM
                • bobotheklown
                  Dell xps 8940 bios master password request / bypass
                  by bobotheklown
                  Looking for anybody that can advise me how to proceed as I sold a Dell XPS 8940 registered to me to a third party; who subsequently returned the item with an enabled BIOS password and does not return communication requests.
                  Is there anybody who can access the master pw for this system? (Service tag 60QVNK3) Or is there a chip I can flash or edit with a ch3413a device/vertyanov jig? Thanks for any help you can provide with this issue. I requested the Master PW from the Dell support portal and was informed that I had been placed in the "paid support queue", as my warranty has expired...
                  01-06-2023, 05:52 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                • F R 2568
                  Dell Latitude 5420 does not start (no post) need help to find the reason why
                  by F R 2568
                  Hello all,
                  this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                  I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                  If the laptop is only connected to the AC adapter (battery removed):
                  When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                  The power/battery...
                  01-08-2025, 05:45 AM
