macbook 820-00165 ppbus short
  • disorder
    • Sep 2015
    • 156
    • france
    hello
    i've just got a macbook air 820-00165 motherboard.
    ppbus_g3h is short du to c7313, a tantalum 62uf 11v capacitor.
    my problem is that i haven't got any capacitor like this.
    can i leave c7313 empty as there is many many capacitor on g3hot line ?
    thank you
  • mon2
    • 14664
    Re: macbook 820-00165 ppbus short
    Yes, you can. Leave it off.
    Just repaired the same board a few minutes ago. SMC reset was stuck low. The board was filthy and the the SMC reset line was ~200 ohms to ground and with an output of 0v2 instead of 3v42.
    After dousing with IPA and cleaning up the reset supervisor - unit is back and working again. Came in with a fake charger and no green / amber light.
    • disorder
      • Sep 2015
      • 156
      • france
      thank you
      • shlomim412
        Macbook Pro a2141 820-01700 - short on PPBUS
        by shlomim412
        Hello
        working on a dead a2141 logicboard - 820-01700
        no power, on usb c ampmeter it's on 5v drawing 0.01a
        visual inspection under the microscope - board look good, no liquid damage on any kind of damage.
        ppbus_g3h is 0.3v, and is shorted to ground showing around 50ohms (continuity beep) and climbing..
        i removed F7000 and F7001 and now getting 12v on PPBAT_G3H..
        also verified the short is on the system side (pin2 of F7000\1)..
        i tried to inject voltage, 1v to ppbus_g3h but it's only drawing...
        07-01-2023, 04:09 AM
      • Stephen
        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
        by Stephen
        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
        02-06-2025, 12:03 PM
      • sdogs
        macbook pro M1 a2338 no video on internal display PP3V3_S2 short
        by sdogs
        Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
        First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
        I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
        06-27-2025, 01:58 PM
      • sdogs
        by sdogs
        06-27-2025, 11:26 AM
      • defdjamel
        internal short cut - 820-02935 -A2992 - macbook pro 16" m3 max
        by defdjamel
        820-02935 - a2992 - macbook pro 16" m3 max
        Laptop: 5V - 0A
        Issue: PPBUS_AON_SPKRAMP_ABC and PPBUS_AON shorted.
        • On PPBUS_AON_SPKRAMP_ABC, capacitor CR635 was damaged (melted) and created an internal short circuit to ground.
        • I removed faulty components (CR635, CR634, CR633) and also chip UR630.
        • Result:
          • PPBUS_AON_SPKRAMP_ABC → still shorted
          • PPBUS_AON → still shorted
        When I inject 3 V / 1 A on PPBUS_AON_SPKRAMP_ABC, heating occurs on pad CR635.
        I suspect that during the failure, the pad and line PPBUS_AON_SPKRAMP_ABC melted into ground( i try to...
        09-20-2025, 06:16 AM
