Socket G3 / rPGA946B Pinout diagram
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Does anyone have the pinout diagram for intel's Socket G3 / rPGA946B
    Best Regards
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • Isabella91
    Possible to convert eMMC Socket to a micro SD Card socket?
    by Isabella91
    I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
    Read/Write a Micro SD Card from an eMMC Socket.
    I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
    Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
    Not to remove...
    01-14-2024, 05:10 PM
  • warsztat
    Acer AN515-57-577G JDIMM1 socket not working.
    by warsztat
    Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
    11-18-2024, 09:13 AM
  • AJ847.63e
    LGA 1700 Socket Replacement Tips & Tricks
    by AJ847.63e
    Hi All,
    Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
    I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
    07-24-2025, 06:57 PM
  • Geomih
    CPU socket replacement soldering profile
    by Geomih
    Hi All - I am hoping someone can help with some pointers (complete noob here!)
    I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
    My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
    The simple stuff like a small memory module isn't a big deal because there are
    12-11-2023, 11:07 AM
