Underfill chips
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Underfill chips
    Today I saw a video from PLD in which he replaced two chips CD3215 that had underfill. It was pretty complicated procedure of removing the chips and cleaning the board. What exactly is the purpose of underfill? Is it to protect chip‘s pins from liquid damage, to improve resistance to stress or shocks or something completely different?
    Thanks.
  • mon2
    • 14561
    Re: Underfill chips
    https://www.henkel-adhesives.com/ca/...hermal%20shock.
    • reformatt
      • Feb 2020
      • 1445
      Re: Underfill chips
      Mainly to prevent movement of the chip and cracking the balls. But board flexion/shock on a MAC is very minimal (compared to something like a phone). Phones maybe, but MAC's? CD3215's are on the edge of the board, so board flexion is going to be almost non existant.
      It's there to hinder repairs, pure and simple. Liquid resistance could be accomplished in many other ways, but I wouldn't say MAC's give any consideration to that in their designs.
      • piernov
        • Jan 2016
        • 4437
        • France
        Re: Underfill chips
        Several MacBooks have been subject to physical stress on the board causing problems. Somewhat common RAM slot issue on 820-3115, common GPU VCore controller issue on 820-3332, less common GMUX problems on the older A1286, possibly also the cause of the common CPU-related failure on A1534…
        They did fix the 820-3332 problem on the following A1398 machines at least.
        Not sure it was really necessary to underfill the USB-C controllers though. At least it's a very good protection against liquid damage but I doubt it was the intended purpose.
        Sadly it indeed it makes the work harder when the failure is caused by something else.
        • ugamazing
          • Jun 2013
          • 171
          • usa
          Re: Underfill chips
          Thankfully, Apple removed the underfill (on USB-C controllers, anyway) on boards after 2017. They probably realized how commonly those chips need replacing, and their own repair facilities likely had to deal with the underfill as well. But the 2016/2017 boards...ugh. The underfill still exists around nands/WiFi ICs and things, but not the CD321* controllers anymore.
          I've read of some certain types of underfill-specific solvents (and acids I think) that can dissolve the underfill in certain cases. But, I've not any experience with them and don't know if any exist for the specific underfill used by Apple.
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • piernov
            NVidia bumpgate
            by piernov
            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
            May complete this post at a later date with more details.
            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
            03-27-2021, 10:34 AM
          • feherhollo
            WSON8 NEW Bios Chips READ, ERROR, ETC.
            by feherhollo
            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
            11-26-2023, 09:33 AM
          • silver60618
            How to clean Liquid Metal from under CPU?
            by silver60618
            Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
            The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
            Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
            07-11-2025, 01:47 PM
          • Hondaman
            Liquid cooling?
            by Hondaman
            I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
            (After previous generation hardware [Gigabyte] didn't...
            05-08-2025, 09:37 PM
