Dell Inspiron 15 LA-9982p No power help please
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Inspiron 15 LA-9982p No power help please
    Very likely shorted PCH. What is the exact resistance(no power connected) at PL301?? Are you getting +1.05V(I beleive no as SUSP# is the enable and missing)??
    • harshana
      • Aug 2022
      • 207
      • Sri Lanka
      PL301 —-> 70ohms
      No I can’t see 1.05v
      • Sephir0th
        • Oct 2020
        • 1282
        Beside the sum of measurements which does not fit to the observations I totally agree with mcplslg123:
        Without this early sequences present the CPU can't heat up. On the other side we have way way to much consumption for the actual state of the board, even when we take a short in mind.
        Also the heating PCH points to a short exactly there. On the other side the resistance of the 1.05V is still fine. But what about the 3VALW? If the resistance is fine there too there is still no reason for this high consumption confirmed then
        So we probably have missing infos and for sure some wrong measurements here, which let us drive in circles.
        How hot in fact is the PCH die. Can you still touch it or will it burn your finger?
        FairRepair on YouTube
        • harshana
          • Aug 2022
          • 207
          • Sri Lanka
          Im away from the board now. But Im sure resistance of 3VALW was okay. and also I saw 3.3v there.
          currently PCH is under a heatsink and for sure it will burn my finger after few seconds if I remove the cover.
          this only happen after I press power button. before the power on signal, everything is normal. No heat appears on PCH before the power signal
          • harshana
            • Aug 2022
            • 207
            • Sri Lanka
            any luck
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #26
              As @sephir0th has already mentioned, I still cant see any reason for PCH heating up as resistance on both 1.05V and 3.3V is ok as per your observations. Since the mb is trigerring, i dont think RTC section is shorted.Honestly, i couldnt figure out the reason for high consumption in absence of SUSP# signal.
              • harshana
                • Aug 2022
                • 207
                • Sri Lanka
                #27
                Here is the reason as I found.
                When I press the power button U2304 gets PCH_PWR_EN signal. (this signal enable PCH power. thats why PCH is heating.
                when I test the resistance of 3VALW_PCH, it only has 55ohms.
                I tested this rail at J513. Is that okay?? I think its lower. what do you think?
                • Sephir0th
                  • Oct 2020
                  • 1282
                  55Ohms at +3VALW_PCH is in fact a partial shorted 3.3V and most likely the reason for the hot PCH. So the 3.3V is not okay like already assumed before.
                  PCH is dead, board is donor.
                  • harshana
                    • Aug 2022
                    • 207
                    • Sri Lanka
                    #29
                    Thank you for the support. Csn you please check my other thread as well. Im stuck there also. Here is the link
                    https://www.badcaps.net/forum/showthread.php?t=109457
                    • zlr8r
                      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                      by zlr8r
                      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                      Ill try and give as much info as I can.
                      Dell Inspiron 17 (7786) Laptop
                      Service Tag: 5J0NHT2
                      Bios: 1.9.0
                      When I received this , it would only flicker on the KB backlight for a second, then off and on.
                      Then it started getting weirder!
                      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                      12-12-2023, 09:31 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • madura2010
                      Dell inspiron 3168 (15299-2) no power
                      by madura2010
                      Dell inspiron 3168 (Board no=15299-2) no power with battery and charger.No charging.
                      But after removing battery, worked perfectly.
                      next day again no power.Then check 19v section.section ok.mosfet driving perfectly.
                      But 3v LDO was not generated.Then i checked the enable signal of the ic.It is perfect according to datasheet.Then i checked the impedence.It is perfect(444).So i replaced the 3v ic.Then worked.
                      Again next day, same issue.then i decided to disconnect the ldo line by cutting the path.After that LDO generated well.Then again connecting...
                      01-28-2024, 09:10 PM
                      DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                      This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                      09-12-2024, 02:15 PM
                    • Scaff
                      Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
                      by Scaff
                      I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
                      06-08-2025, 01:46 AM
