Macbook A1932 Intermittent Backlight Issue 820-01521
  • Instafixx
    • Jul 2022
    • 374
    • India
    #41
    Re: Macbook A1932 Intermittent Backlight Issue 820-01521
    Originally posted by mon2
    Can you share the meter setting?
    If you short your meter probes, do you see the same resistance readings?
    FINAL UPDATE.
    Replaced the Fuse F6700 yesterday and the trackpad started giving very light haptic feedback. Today morning it is giving proper haptic feedback but the backlight issue is back again.
    Removed the Fuse F6700.
    Voltage at Pin 1 is 12.6V and Resistance to Ground at Pin 1 is 470.
    After Removing the Fuse, the Backlight Issue is fine but the Haptic is Gone Again.
    • Instafixx
      • Jul 2022
      • 374
      • India
      #42
      FINALLY
      We ahead and replaced the R5610 and L6700 both connected to the Fuse F6700. See Attached
      Now there is no Intermittent Backlight issue or Trackpad Haptic Issue. Will keep it under observation for 1 more day and let you know.
      Would like to thank BADCAPS FORUM and Mon2 for prompt responses and guidance.
      • Instafixx
        • Jul 2022
        • 374
        • India
        #43
        Are you able to probe the pads @ J6700 connector ?
        The J6700 connector also contains the signals of interest.
        We ran a jumper wire from C6712 and the screen is giving issue.
        When there is No Image, the Voltage still remains 1.8V.
        Removing F6700 solves the Backlight issue but the Trackpad Haptic Starts giving problem.
        Current Status of the Board -
        Replaced F6700,L6700 and R5610.
        I am in a total fix. Please help.
        • mon2
          • Dec 2019
          • 13995
          When the lid is closed, what is the voltage at C6712?
          Is this an image or backlight issue? Can you see the graphics with a flashlight around the front face of the display when there is no display?
          Are you able to monitor the lcd backlight voltage when the logic board is mounted in the case?
          • Instafixx
            • Jul 2022
            • 374
            • India
            #45
            When the LID is closed, C6712 has 0 Volts.
            Its an Image Issue. Cannot see anything with the flashlight.
            The issue is very erratic, doesnt happen always - It happened 2 times now and then with LID open and No Image on Screen the voltage at C6712 was 1.8V.
            The logic Board is mounted , tell me which components to check?
            • mon2
              • Dec 2019
              • 13995
              If you remove the track pad fuse, the display will always show an image?
              What is the voltage at c6712 when the track pad fuse is removed?
              • Instafixx
                • Jul 2022
                • 374
                • India
                #47
                Removing the trackpad is necessary? I am pretty sure the trackpad isnt faulty - No Corrosion or Dirt there.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  #48
                  When we removed the tracpad fuse the Display will function as per normal. Even when the old fuse was damaged and the PPBUS_G3H_TPAD_FLT was getting no voltage the Image Issue was fine for 2-3 days.
                  • mon2
                    • Dec 2019
                    • 13995
                    Do you still have the following from post #10?
                    2. Secondly when we re-assemble the device, it doesnt switch on automatically or by pressing the p[ower button, we have to first put it on charge and then press the power button to switch it on.
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      #50
                      Yes.
                      When you pull out the battery connector and put it back, You will have to first connect the charger wait for the battery charging sign to come , then press the Power Button for it to switch on.
                      • mon2
                        • Dec 2019
                        • 13995
                        That is not normal. You likely have a leaky mosfet.
                        Remove all power. Meter in resistance mode.
                        Check the resistance of the battery mosfet @ Q7065:
                        source (1-2-3) & drain (5-6-7-8)
                        source (1-2-3) & gate (4)
                        gate (4) & drain (5-6-7-8)
                        Post the resistance values & the scale used on your meter for these measurements.
                        As a quick test - remove Q7065 off the logic board -> then see if the logic board will power up normally without this mosfet using only the external power adapter.
                        • Instafixx
                          • Jul 2022
                          • 374
                          • India
                          #52
                          Any reference on how to probe a mosfet? The terms Source,Drain and Gate are alien to me.
                          Yes will remove the mosfet and see if its powering on or not.
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            #53
                            That is not normal.
                            Why?
                            • mon2
                              • Dec 2019
                              • 13995
                              Originally posted by piernov
                              Why?
                              Does this logic board require a good battery to turn on? I would expect this logic board to turn on with only a good power adapter.
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                #55
                                That's not what they said.
                                However some machines since T2 have inconsistent behaviour regarding the presence of the battery (A2141 is known for that but I believe it's also a problem on some even newer ones), so best to try with a known good battery if all looks good but it doesn't actually turn on or doesn't go past low battery symbol.
                                • Instafixx
                                  • Jul 2022
                                  • 374
                                  • India
                                  #56
                                  Removed the Q7065 and same issue. It still does not boot up by pressing the power button for the first time.
                                  Also now even if we remove the FUSE F6700, there is intermittent No Display Issue along with the Trackpad not vibrating.
                                  • mon2
                                    • Dec 2019
                                    • 13995
                                    Check the removed mosfet with a resistance check:
                                    Just to confirm there is no fault with this mosfet.
                                    Then, place back this removed mosfet.
                                    Does this battery charge if left on ?
                                    As per @Piernov's comments, test with a known good battery.
                                    • piernov
                                      • Jan 2016
                                      • 4435
                                      • France
                                      #58
                                      Originally posted by Instafixx
                                      Yes.
                                      This is normal. Looking at the battery connector circuit will explain why.
                                      • Instafixx
                                        • Jul 2022
                                        • 374
                                        • India
                                        #59
                                        This battery charges when left on. There is no power or battery issue.
                                        Do not have a known good battery.
                                        What should i do?
                                        • mon2
                                          • Dec 2019
                                          • 13995
                                          What should i do?
                                          Ok - so this is your known good battery if it the battery charges to the full potential -> can report the # of charges / stats of the battery pack -> can operate without the external adapter (after it is charged) and power the laptop for a normal duration of use.
                                          If the battery depletes quickly, etc. then the pack is weak and should be replaced.
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            🛠 Original Issue
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • bouch
                                            unlock macbook air A1932 2019
                                            by bouch
                                            hi
                                            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                            I need help or information?
                                            Does anyone have the minat2 activator 1.4 software?
                                            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                            Thank yo...
                                            03-12-2025, 10:14 AM
                                          • pcbmaniac
                                            MacBook A1278 (3115) No PPBUS_G3H Issue
                                            by pcbmaniac
                                            Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                            I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                            1. U7000 Measurements:
                                              • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                            2. Resistors:
                                              • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                            Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                            • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                            12-02-2024, 04:12 PM
                                          • sofles
                                            Macbook a1707 2017 model 820-00928 GPU issue
                                            by sofles
                                            Hello there
                                            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                            11-21-2024, 05:25 AM
                                          • Stephen
                                            A2141 MacBook Pro 16" lid sensor issue.
                                            by Stephen
                                            Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                                            11-01-2024, 03:45 PM
