Asus X455L Short Mosfet
  • dqtech
    Badcaps
    • Jul 2018
    • 640
    • N/A
    I got this laptop from friend with problem short 19v....when i check this 2 mosfet getting short...i remove that mosfet and confirm that mosfet is short...
    and check that 2 capacitor PC9009 and PC9004 pad is also short...already check where that capacitor goes and came from but cannot find the main problem...please help
  • dqtech
    Badcaps
    • Jul 2018
    • 640
    • N/A
    Re: Asus X455L Short Mosfet
    already remove charging ic PU9001 but that capacitor still short
    • mon2
      • Dec 2019
      • 14698
      Remove all power -> meter in resistance mode.
      Check the resistance to ground of your 2 x DCin mosfets.
      These are PQ8801 & PQ8802.
      Review the resistance between:
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Post the resistance readings and the scale used on your meter for these tests.
      Repeat for PQ8802. Often the 2nd mosfet gets damaged.
      Do also confirm the resistance to ground of the main power rail which will be mated with the 2nd mosfet (PQ8802) - drain pins (5-6-7-8).
      • dqtech
        Badcaps
        • Jul 2018
        • 640
        • N/A
        sorry the capacitor pad that short is PC8811 and PC8813
        • mon2
          • Dec 2019
          • 14698
          Remove all power. Meter in resistance mode.
          What are the resistance readings of these parts to ground?
          Carefully remove each but do not lose the parts. Use low air pressure so other parts are not lost.
          Is the short gone if you remove these 2 parts?
          Measure the resistance of these capacitors when they are removed off the board. Is the resistance very low for these parts?
          • DanielDacko
            • Mar 2015
            • 328
            • Macedonia
            Do as @mon2 says, he is guiding you properly.
            I don't provide help for people using CH341A and a clip.
            • dqtech
              Badcaps
              • Jul 2018
              • 640
              • N/A
              those capacitor still short when i remove that 2 mosfet...the short only gone when i remove resistor PR8806 and PR8807
              • questore
                HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
                by questore
                Hello everyone.
                Someone brought this poor hp in.
                All power rails had normal resistances so i turned it on. Instant power cutoff...
                First mosfet was shorted so replaced it...
                After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
                After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
                Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
                08-25-2025, 10:09 AM
              • AppleLover123
                Asus X712EA 3 volts after the first mosfet
                by AppleLover123
                Hey guys,
                i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                Now i thought something...
                12-15-2024, 07:49 AM
              • Scotchmist
                Asus GA502D keeps blowing mosfet
                by Scotchmist
                I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                I have removed the mosfet and can run the laptop no problem
                The MOSFET is FDPC5018SG
                Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                08-24-2024, 02:23 PM
              • jkyoho
                ASUS TUF FA506IV-AS76 vram mosfet short, then battery cant charge
                by jkyoho
                I recently fixed a FA506IV cam with Vram mosfet short on Vin(19v)to ground. Got both mosfet replaced and now laptop could turns on and GPU everything works but battery not charging. Battery status shows 100% on both BIOS page and Windows system.
                Measured voltage got 0.3v on battery red lead not going up. charging mosfet gate low and 19v not passing through inductor.
                I also tried dc bench supply 14v charge directly onto battery but seems not drawing anthing.
                Any idea?
                07-11-2022, 03:39 PM
              • aaronkatrini
                DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                by aaronkatrini
                I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                - Put the card in my testing motherboard and start running Heaven benchmark
                - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                - Try to start it again and I get a slight move from the PSU fan - a clear short
                - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                - Put the...
                05-18-2025, 04:18 PM
