LA-C501P No ACDRV??
  • dspok
    • Jan 2014
    • 553
    • Nepal
    LA-C501P No ACDRV??
    I have LA-C501P Mainboard in which VCC, ACDET are ok but NO ACDRV. Can anybody let me know what I'm missing?
    Thanks,
  • mon2
    • Dec 2019
    • 14140
    Re: No ACDRV??
    Hi.
    1) post all voltage values on the charger IC @ PUB01. It is important to review. I posted a request for the detailed operation of the TI charger ICs on the TI forum and their engineer group replied with a great response.
    You can find it here:
    https://e2e.ti.com/support/power-man...114776#4114776
    2) often faults are with the first 2 mosfets. You can confirm the status of the first 2 mosfets (aka DCin mosfets) by removing all power.
    Meter in resistance mode.
    Measure the resistance of each of the 2 x dcin mosfets as follows:
    Source (1-2-3) & drain (5-6-7-8)
    Source (1-2-3) & gate (4)
    Gate (4) & drain (5-6-7-8)
    Post each measurement and the meter scale used.
    Repeat for the next mosfet.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: No ACDRV??
      CMSRC present??
      • Udemzy
        • May 2017
        • 161
        • Guatemala
        Re: LA-C501P No ACDRV??
        If PQB1 doesn't switch,how then will CMSRC generate? To switch the MOSFET then ACDRV must be generated.
        The practical way to generate ACDRV.
        Check the impedance of the ACFET and RBFET( on diode mode,it should be above 0.400)
        ACN and ACP communication with CLR(very important)
        Impedance of CMSRC
        Impedance of CLR
        Impedance of REGN,ACDET,ACOK
        Voltage on VCC,ACDET,REGN and ACOK
        • Udemzy
          • May 2017
          • 161
          • Guatemala
          The reason why it's advisable to check the impedance first is because from experience, ACN and ACP communication with CLR is important, the communication line of ACN with CLR was broken (not communicating) and this caused the chip not to generate ACOk.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            @Udemzy, The OP has not given any measurement for dc-in fets voltage readings, so not possible to conclude whether CMSRC is present or not. Say if dc-in mosfet is partially shorted, there will be cmsrc present but no ACDRV. This way we can get an idea whether dc-in fets are wrong or not as OP has not given any measuremnts which @mon2 advised.
            • Udemzy
              • May 2017
              • 161
              • Guatemala
              I was replying base on post #3 and how the architecture works,ACDRV will come before CMSRC.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                We all know the theory part.
                • Udemzy
                  • May 2017
                  • 161
                  • Guatemala
                  We are both here to help.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Agreed friend
                    • dspok
                      • Jan 2014
                      • 553
                      • Nepal
                      Impedance of CMSRC
                      Impedance of CLR
                      Thanks for reply, both ACFET and RBFET is +0.500 on diode mode source to drain only. Didn't understand CLR but ACN and ACP continuity is ok.
                      VCC=19v
                      ACDET=2.6v
                      REGN=6.0v
                      ACOK is missing.
                      Plz note: I fixed hp machine where ACFET wasn't ok, fixed with replacement. Now same issue on NM-B241.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        SDA/SCL present?? What is the voltage on ILIM?? DK1-voltage on both sides?? Try removing DK1 and see if ACOK appears on charging IC.
                        • Sephir0th
                          • Oct 2020
                          • 1282
                          ACOK will be pulled up from +3VL in this case so it can't be up if the LDO isn't working.
                          Imho best bet is to replace the charging IC right now
                          FairRepair on YouTube
                          • dspok
                            • Jan 2014
                            • 553
                            • Nepal
                            I already changed charging IC still PQ311 isn't switching. There is 0v on gate.
                            schematic attached.
                            • mon2
                              • Dec 2019
                              • 14140
                              See attached.
                              1) Charger IC is a typical TI (BQ series) IC and is driving n-channel mosfets.
                              2) Carefully, with the power adapter connected - measure the voltage of:
                              pin # 4 = ACDRV (PU301)
                              This is the same voltage that is used to ENABLE / DISABLE the DCin mosfets.
                              3) Confirm that the resistor @ PR310 is present. With the power OFF -> confirm this resistor is ~4k ohms and that it does indeed mate with the mosfets.
                              4) Carefully, measure the voltage on each pin of PU301.
                              Do you have a voltage @ REGN ? (pin # 24)
                              This pin should be ~6 volts if all is well with PU301.
                              Post each measurement.
                              • Udemzy
                                • May 2017
                                • 161
                                • Guatemala
                                VCC=19v
                                ACDET=2.6v
                                REGN=6.0v
                                ACOK is missing.
                                Check CLR communication with ACN and ACP with continuity, check impedance of CMSRC and impedance of ACOk.
                                This is all you need to release ACOk and when ACOk is available then ACDRV will come and by the way the IC you replace it with,is it good? Are you 100 percent sure about it?
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  Also in my opinion I can only think of colder solder joints around at charging controller and surrounding components left. Of course missing or failed resistor possible too.
                                  Especially because we don't have seen any pictures about your work and the area in question so far.
                                  • dspok
                                    • Jan 2014
                                    • 553
                                    • Nepal
                                    Originally posted by mon2
                                    See attached.
                                    Yes it is.
                                    0.00v
                                    Confirmed, and yes it is 4kohms.
                                    Yes it has 6.0v
                                    Pin1: 0v
                                    Pin2:0v
                                    Pin3:0.0v
                                    Pin4:0.0v
                                    Pin5:0.0v
                                    Pin6:2.71v
                                    Pin7:0.0v
                                    Pin8:0.0v
                                    Pin9:0.0v
                                    Pin10:0.0v
                                    Pin11:0.0v
                                    Pin12:.00v
                                    Pin13:0.18v
                                    Pin14:0.16v
                                    Pin15:0.0v
                                    Pin16:0.0v
                                    Pin17:0.13v
                                    Pin18:0.13v
                                    Pin19:0.13v
                                    Pin20:0.13v
                                    Pin21:0.0v
                                    Pin22:0.0v
                                    Pin23:0.0v
                                    Pin24:5.99v
                                    Pin25:5.66v
                                    Pin26:0.13v
                                    Pin27:0.13v
                                    Pin28:19v
                                    • dspok
                                      • Jan 2014
                                      • 553
                                      • Nepal
                                      Here are the pictures the are I have worked so far.
                                      • mon2
                                        • Dec 2019
                                        • 14140
                                        Pin20:0.13v
                                        From the voltage on pin # 20 (VCC), the charger IC @ PUB01 is not being powered.
                                        See attached.
                                        Review the parts that have been highlighted.
                                        The dual diode and series resistor must be present and working to allow for the raw ~19v to reach this charger IC to power up this logic board.
                                        On a normal logic board, pin #20 should be ~19 volts. Confirm it and update this thread.
                                        Start with the voltage check on each pin of PDB1 (dual diode). Pin #1 should be about the same as the adapter voltage.
                                        • zaurus81
                                          Asus TUF Gaming F16 (2024) FX607J no power no ACDRV
                                          by zaurus81
                                          Hi all, I have a Asus TUF Gaming F16 (2024) FX607J motherboard with liquid damage. The oxide on the board was removed before giving it to me. This made it more difficult to repair. Also they did not give me the power supply.
                                          When I connect the 20 volts with the bench power supply I get 4.3 volts on the main power line. If I remove the power sensing resistor I get 20 volts on one side (first 2 mosfets are ok) and 4.3 volts on the main power line (see photo). How is this possible?? I thought the 4.3 volts was coming from the battery mosfet so I unsoldered it and tested it. It is ok too. I...
                                          11-21-2024, 05:04 AM
                                        • BlackScreen_22
                                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                          by BlackScreen_22
                                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                          I had no problems connecting mosfets and capacitors,...
                                          08-27-2024, 12:46 PM
                                        • kotel studios
                                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                          by kotel studios
                                          Finally got time to fix this board up.
                                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                          04-22-2025, 05:08 AM
                                        • zaurus81
                                          HP 15-cb028nl (dag75ambad0 rev. d) no charge battery
                                          by zaurus81
                                          Hi all, I have a HP 15-cb028nl (dag75ambad0 rev. d) that turns on but does not charge the battery. The laptop arrived with the super I/O (ITE IT8987E BXA) burned. After replacing the EC, it turns on but does not charge the battery. Below are the voltages on the pins of the bq24738h, with and without the battery inserted:
                                          WITHOUT BATTERY WITH BATTERY
                                          PIN1 (ACN)= 19.76 V PIN1 (ACN)= 19.76 V
                                          05-06-2025, 09:48 AM
                                        • flerre
                                          Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                          by flerre
                                          Hi!
                                          Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                          No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                          So, could I safely assume all of these 3 mosfets are...
                                          03-13-2022, 12:14 PM
