Re: Alienware M18x Shorted CPU Mosfet
A photo of the replaced Mosfet and the two caps, and NCP6151 would help.
Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
I'm getting a reading of 9ohms to ground on the CPU rail which had the shorted mosfet. Dead CPU?Leave a comment:
Probably CPU took 19V... But post the reading.Leave a comment:
The CPU may be damaged. You can check the resistance to ground of the CPU power rail. Remove all power. Meter in lowest resistance scale.
Check the resistance to ground of the CPU rail and post the reading.Leave a comment:
I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal going to the NCP6151 but it seems to be not telling the mosfets to open and send power to the CPU. All resistors look to be fine around the NCP6151.
Now given the shorted mosfet plus the damage it caused is it likely that the CPU is also dead and would that cause the issue as described?Tags: None
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by ktmmotocrossHello.
Have this MSI Katana 17 MS-15851 that work only on battery with adapter and have first DC mosfet shorted. After replace not work without battery. On charger DC+ get power only for few seconds and it goes down... -
by ReintarFirst of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...08-30-2024, 06:13 AM - Loading...
