IT8585e and IT8586e compatible?
  • Zibbo
    • Mar 2017
    • 201
    • Zimbabwe
    I have an ASUS P552LA_LJ motherboard wit a shorted IT8585e EC. I do not have it but I have a lot of IT8586e ECs, are these chips compatible? I can't find IT8585e pinout anywhere. Thanks
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: IT8585e and IT8586e compatible?
    In general, no two SIO chips with different models are compatible. Order exactly the same chip.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      IT8585 & IT8586 are not compatible.
      • Zibbo
        • Mar 2017
        • 201
        • Zimbabwe
        Thank you
        • xloomx
          • Oct 2020
          • 49
          • Argentina
          thanks!
          • Francesc V.
            Are these 2 chips both compatible (GR8313) vs (HY510N)??
            by Francesc V.
            Hi:
            I have a SMPS that has GR8313 as power supply supervisor chip. I have already ordered these chips, but today doing housekeeping and doing some catalogue of all "shit", I realised that HY510N chip which I already have, has the same pinout and I would say will do the job.
            Do you think that I could use HY510N instead of GR8313 for trying to repair the SMPS?
            Attaching both data sheets for a fast checking.
            Thanks in advance.
            Francesc....
            03-06-2025, 05:57 AM
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • feherhollo
            WSON8 NEW Bios Chips READ, ERROR, ETC.
            by feherhollo
            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
            11-26-2023, 09:33 AM
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • Prott
            [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
            by Prott
            Hello dear badcappers!
            The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
            Backstory:
            After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
            If there is a way to narrow down which memory module is faulty it would make my life much...
            06-03-2024, 12:05 PM
