Starting problem HP -dw1033dx LA-H325P
  • Tend0
    E.E.C.S
    • Oct 2021
    • 93
    • Burkina Faso
    Hi there
    I leave it to you because out of ideas I don't know how to troubleshoot this computer
    Here I received the computer which did not turn on at all and no charging light
    After checking I quickly found that the main 19v line did not cross the 1st MOSFET and that it was burnt
    After replacing it I have the lights and the PC turns on after 3s and then turns off after a short circuit to ground
    I don't know where to check since I don't have a diagram or brd
    The card refs: FPW50 LA-H325P
    Thanks in advance
  • mon2
    • 14667
    Re: Problème de démarrage HP -dw1033dx
    What is the charger IC near this acfet ?
    Post the markings from the topside of the IC.
    • Tend0
      E.E.C.S
      • Oct 2021
      • 93
      • Burkina Faso
      3h=8g
      • Tend0
        E.E.C.S
        • Oct 2021
        • 93
        • Burkina Faso
        Après vérification le bios n'est pas alimenté j'ai pas les 3v3 sur le bios
        After checking the bios is not powered I do not have 3v3 on the bios
          • 21907
          Read your private messages please,post in english !!!!!!!!!!
            • 21907
            Is the bios chip 1.8V
              • 21907
              3h=8g
              Is it a capital H or lower case h ,post a picture of it
              • lpraderi
                • Dec 2017
                • 31
                • Uruguay
                Re: Starting problem HP -dw1033dx LA-H325P
                LA-H325P uses BQ24725A Charger IC from Texas Instrument.
                You pointed to 3V3ALW/5VALW controller IC.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Follow simple basics:
                  01.Check resistance between
                  Source-Gate
                  Source-Drain
                  Gate-Drain
                  of both the dc-in fets.
                  02.Locate the CLR(Current sensing resistor) just after the 2 dc-in mosfets or near to charging IC. The location may vary but easily findable. Remove it from mb and then check resistance to GND on both pads of CLR.
                  Post your findings here.
                  • ravi_1617
                    Lenovo B540 ,Starting Problem
                    by ravi_1617
                    Hello !
                    Model Lenovo B540
                    Board Details 09244-1
                    LA14 DIS MB
                    48.4DMO4.01.1
                    This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                    when connected CMOS dont start.
                    3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                    One more thing i want to mention ( by mistake i started at...
                    10-14-2025, 02:08 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Zeonalbasta
                    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                    by Zeonalbasta
                    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                    09-13-2024, 01:17 PM
                  • Gibon378
                    Problem with stopping audio and video for no reason
                    by Gibon378
                    PC Specs:
                    • CPU: Ryzen 5 1600
                    • GPU: GTX 1080 Palit JetStream
                    • MOBO: ASRock ab350 PRO4
                    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                    • PSU: XFX 650W (don't remember what model)
                    • OS SSD: ADATA SP920
                    • OS: Windows 10 21H2
                    Problem description:
                    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                    11-19-2022, 09:41 AM
                  • perzyk23
                    Lenovo T580 - LCD Panel problem - error 0288
                    by perzyk23
                    Good morning,
                    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                    10-25-2024, 12:42 AM
