A1286 820-2915b chime ok, but no image no bklight
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    I have this a1286 with minor water damage, after cleaned ISL area turns on and chimes , load os but: no image no backlight.... LCD_PWR_EN is 0vol ..
    I have done gmux bypass to many a1286s with gpu issues, so though this would be the case. routed jumpers to avoid the gpu and removed resistor r8911 as usual to disable ati gpu... but still no LCD_PWR_EN signal...
    what can be going on to not have LCD_PWR_EN enabled? i do have 3.3v in pin 4 at lcd connector but not pins 2,3, because u9000 is not enabled by this missing LCD_PWR_EN
    thanks in advance
    pd i did not remove gmuch chi only bypassed in site like this img:
    Marcelo J
  • mon2
    • Dec 2019
    • 14012
    Re: A1286 820-2915b chime ok, but no image no bklight
    What is the voltage of R9678, pin # 1 ?
    • marce002
      • May 2018
      • 316
      • Argentine
      Hi mon it is 8.2mV at #1 and 2.66V at #2.. resistor is in range
      Marcelo J
      • mon2
        • Dec 2019
        • 14012
        Check the resistance to ground of LCD_PWR_EN pin. Any liquid damage in this area ? Trace is ok from source (U9600) to target ?
        • marce002
          • May 2018
          • 316
          • Argentine
          it is 8.2kohm and traces are ok there around...
          remember that i have a mod jumper from #1 of r9678 (lcd_pwr_en) to R2015 pin 1 (lvds_ig_panel_pwr)
          Marcelo J
          • marce002
            • May 2018
            • 316
            • Argentine
            R2015 is the source for my lcd_pwr_en after my mod.... is it? .. which in fact should be 100kohm and i have it at around 8kohm... mmm
            Marcelo J
            • marce002
              • May 2018
              • 316
              • Argentine
              bad pch?
              Marcelo J
              • mon2
                • Dec 2019
                • 14012
                But you don't have an image?
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  nop no image no backlight but do have brain ...replaced that resistor and after soldered in it is 8kohm so in circuit resistor parallel afects messurement.
                  Marcelo J
                  • mon2
                    • Dec 2019
                    • 14012
                    Do you get external video?
                    • marce002
                      • May 2018
                      • 316
                      • Argentine
                      please understand me.. i ve just made a bypass in order to fix gpu issues and that excludes external monitor usage
                      Marcelo J
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        fixed it was bad corrupted efi bios so if you have chime but lcd pwr on signal not enabled might NOT be a bad pch or bad connector screen or coils around... thks mon
                        Marcelo J
                        • mon2
                          • Dec 2019
                          • 14012
                          Well done! Thanks for the update.
                          • gurangax
                            • Apr 2020
                            • 34
                            • Malaysia
                            Thanks for tips. I managed to fix mine same problem. flashed with other firmware and it worked.
                            • durchfall
                              MacBook 2011 A1286 power cycle, no chime
                              by durchfall
                              I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
                              What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
                              01-11-2023, 05:56 AM
                            • survivalbloke
                              Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
                              by survivalbloke
                              Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
                              06-14-2023, 11:45 AM
                            • zpi
                              A1466 820-00165 Chime and freeze on osc loading, with battery no chime.
                              by zpi
                              Hey guys, so i have here really strange board...
                              These steps needs to be done to get a chime board starts to load osx but freezes with no loading bar:
                              1.Disconnect battery
                              2.P+R+CMD+OPT to pram reset
                              3.After only 2-7 atempts to pram reset i get chime.
                              4.Then i get chime allways, but if i connect battery, then boards stops to chime till i make steps from 1 to 3.
                              Board looked very clean, no liquid damage. Already replaced isl6259 and SMC, good known battery. Still same problem, sometimes turned off board without battery uses 0.03...
                              11-10-2020, 04:42 PM
                            • Comp_Pro
                              Macbook Air 820-00165 Static Chime Sound
                              by Comp_Pro
                              Hello all,
                              I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                              11-02-2023, 03:23 PM
                            • Shadrack Annan
                              MACBOOK PRO A1286 820-2565-A
                              by Shadrack Annan
                              PLEASE I NEED MACBOOK PRO A1286 820-2565-A BOARDVIEW
                              06-26-2025, 03:44 AM
